Did I Mess Up???
Old Aug 26, 2004 | 03:43 PM
Simple Man's Avatar
Simple Man
Did I Mess Up???
I got an '80 f-100 with I-6 and t-18. Found an np435 for $60, it was mounted behind either a 360 or 390. Will the np mount to my I-6 bellhousing?
Just to be sure I have what I think I have here are the numbers that are on the transmission,
On top; a gear looking symbol with np in the middle
also a wagon wheel with 68 in the middle
On passenger side of trans; cast in housing C-96391-S
On a metal tag; C9TA 7003AA FL6
Also on metal tag; 3 24 69 435
Old Aug 26, 2004 | 05:11 PM
bremen242's Avatar
bremen242
should fit. Measure the input shafts first though.
Old Aug 27, 2004 | 09:22 AM
Oscar Meier's Avatar
Oscar Meier
Why do you want to switch from the 18 to 435?
Old Aug 27, 2004 | 02:32 PM
Simple Man's Avatar
Simple Man
I couldn't find a t18 anywhere close for anywhere near the money.
Old Aug 27, 2004 | 04:08 PM
Oscar Meier
You didn't mention that the T-18 was bad. Depending on the T-18 you have, your 435 may have a much lower 1st gear (Granny gear) than you have now.
This may not be a problem- since most drive the 18 & 435 like a 3-spd starting off in 2nd gear.
Good luck with the change out.
Oscar
OzFTrucker
Aug 24, 2008 03:53 PM
DJOHNSTON78
1978 - 1996 Big Bronco
May 10, 2008 12:11 PM
lenrsmith
Mar 3, 2004 01:53 AM
Goodold71
Feb 26, 2003 10:34 PM
aunchman
Aug 5, 2002 04:55 PM
