Are you planning on keeping the 31's ?
In that case your stock Gear Ratio might be ok. If you plan on lowering your gears I would go for 4.27. I suggest you study the gear ratio table at: Gear Ratio Chart
You really should narrow down what tire size you want to run before deciding on gears. Also, knowing what engine and transmission you have and how you intend to use the truck would be helpful for anyone offering gearing advice (daily driver, strictly off-road, mud bogger or rock crawler, towing/no towing, ect). Well, I guess we can assume mud will be a part of it...
