1978 - 1996 Big Bronco
Transmission question
Old Aug 26, 2004 | 01:16 AM
65kcoupe's Avatar
65kcoupe
Ok, when shifting from park to reverse i almost always get a firm jolt. Same with reverse to drive...slightly less though. The other day my dad was driving my truck for the first time...and he has a tendency to slide the car into drive before the car stops completely. For some reason the car shifts smoother when you do this...so my question is...Is this harmful for the trans? I would assume it is..if it is why does the car shift smoother when you do it?
btw i have a 95 with a 351 and the sought after *sarcasm* E40D.
Old Aug 26, 2004 | 06:53 AM
fcarruth's Avatar
fcarruth
Have you checked your u-joints ? Also could be the slip joint at the rear of the shaft. You can take the shaft off, remove the band holding the boot on, pull the shaft apart and clean and lube the slip joint. Put the shaft back together, lube it real good again and attach the boot back on with a plastic wire tie.
Good luck,
Old Aug 26, 2004 | 07:59 AM
jacque_strap's Avatar
jacque_strap
I have a the EXACT same problem. Has been driving me nuts for weeks now. I just paid $1800 CDN to have my E40D rebuilt with the upgrades and it still seems to shift hard from Park to Reverse and Drive. I figure its not the tranny because the guy that did my transmission was one the of the best. This doesn't really solve our problem but thought I'd add that in. Please let me know what you find out! Good Luck!
Old Aug 26, 2004 | 10:50 AM
broncoman's Avatar
broncoman
I have talked to several people and one guy said that its just the way it is. He has seen trucks that have had 100's of thousand's of kms on it with no ill effects from this clunk. Live with it.
My truck does the same. Lubing slip joint may help somewhat.
Old Aug 26, 2004 | 10:55 AM
stupato's Avatar
stupato
ditto here...if i let the truck warm up a little...it usually goes away...but if i'm impatient...i shift from P to D first then back up to R...that drop from P to R just scares me
Old Aug 26, 2004 | 12:22 PM
AQUARIES1's Avatar
AQUARIES1
Unhappy Clunk, Eo4d, Updates, Etc.
Hello, It's interesting reading this threadandI thought I'd throw in my 2 cents.
I had the clunk for a couple years and found mine this year when the Bronco developed a vibration. The U joints were bad. There are no lub fittings on them and the mileage just took it's toll because lack of lub.
Next because we talking EO4D I just had a catatrophic failure. Had EO4D trans overhauled ($2K) last year @ 97,000 miles. This week @ 110,000 miles the planetary gears failed. The explanation from the New Trans Shop is this:
Th early EO4Ds had an aluminum carrier assembly with a brass thrust plate. The plate and assembly wears down and blocks lubrication to the gears. Thus gear failure. There are no replacement parts for the original unit, so the Old Trans Shop didn't touch it. The new assembly is expensive. The updated assembly has a plate with needle bearings, this to solve the problem. So the old shop skipped the update $, so I can spend another $1000 a year later.
So WARNING if you have an early EO4D with the old design still in it, your miles are limited.
Shafted
Old Aug 26, 2004 | 02:23 PM
jdmorg's Avatar
jdmorg
I can't say what to do when going from P to R. I have the same problem, and it's worse when I go from R to D or vice versa. I find that putting it into neutral before swithing from D to R or R to D let's the u-joints relax a bit, and the force isn't as bad. It still needs to be fixed, but at least it's not as brutal a shift.
Can anyone hear them spinning? Last time this happened, it was my CV Joint. I may have another bad CV, but it is at least one of the two.
Old Aug 27, 2004 | 09:54 AM
AQUARIES1's Avatar
AQUARIES1
Lightbulb
It was hard to verify. We did it by one person lieing under the truck while the other shifted gears. Even though the noise was in front all 3 joints were bad. I had let it go until developed some vibration.
Old Aug 27, 2004 | 12:36 PM
bronco5.8's Avatar
bronco5.8
When you shift from park to reverse is your truck on a hill/incline without the parking brake engaged. Because this puts a load on the tranny from the weight of the truck while it's in park.
Another problem would be if the rpm's is too high this will give you a jolt as well. As mentioned above check your u-joints, slip-joint and also check your tranny mount.
Warr
