Codes what to do
Old Jun 2, 1999 | 03:44 PM
BExplorer's Avatar
BExplorer
Codes what to do
I everyone, I have a 94 Explorer, the computer gives me some codes but I dont know what to do with em.Here's what the Haynes manual say's about it:
1- 14 Profile ignition pick-up circuit fault
2- 22 Manifold absolute/baro pressure sensor out of range
3- 34 EGR valve pressure transducer/position sensor sonic voltage above closed limit
4- 42 Heated oxygen sensor cicuit indicates system rich, right side
I had pinking probleme before that, I cleaned the MAF sensor on the air filter housing, I also changed the EGR valve(it got some codes out but still), if someone could help me point out the sensors or action to take, because Haynes is imcomplete on that subject. Thanks in advance
Old Jun 9, 1999 | 11:09 PM
pastmsater
Guest
Posts: n/a
Codes what to do
you might replace the egr sensor, and the O2 sensor. it might help you out
Old Jun 11, 1999 | 04:33 PM
Vito in TN's Avatar
Vito in TN
Codes what to do
maniac2025
1997 - 2003 F150
Aug 15, 2011 08:06 PM
DJdemon6696
May 8, 2007 07:57 PM
prerunner
4 Cylinder Engines
Apr 5, 2006 06:29 AM
travlnman
3.8 & 4.2L V6
Sep 8, 2004 09:20 AM
Hartwood
Nov 13, 2001 12:56 AM
