To start with I have a 92 f150 300 i6, Mazda 5 speed, 2.73 gears,2 wd all stock. I am currently running 235 75R15 tires. What are the pros and cons of jumping up tire sizes? I prefer the looks of a truck with larger tires. Also what is the largest tire size that will fit a stock 4x2, with out putting a lift on the truck.
With 2.73 gears, I wouldn't go any bigger than the stock size. Those are very high gears. Going to a larger tire size will make the effective gear ratio even higher (lower numerically) and work the engine harder on hills and when starting from a stop.
That is also an unusually high ratio for a '92 truck. Stock gearing was usually 3.08 or 3.55, with 3.31 or something like that also used but not alot. Are you sure you have 2.73's? 2.73 also doesn't sound like a standard ratio number for an 8.8" or Dana 44 axle. You probably have the 8.8". I'm not quite sure the 8.8 was even available with a ratio that high. Did you mean to say 3.73? What is the axle code on your door sticker?
There are no pros going to larger than stock tires. Lower power, lower gas milage, higher center of gravity. Probably some others I haven't thought of......Van
Well it could theoretically give you better mileage, seeing as a larger diameter will give you more distance for each revolution, providing you don't go so big as seriously increase the weight of the tire/wheel combination. You'll definetly want to lower your gears, and I don't know how big you can go without rubbing. My 31's rub just a little on a hard left turn, and that's with 2" lift coils.
I have the a 95 300 I6, Mazada 5sp, with 3.08 gears. I'm running 31-10.50's with no rubbing. I lost a little getup with the larger tires, but gained a considerable ground clearance. Looks better as well. you might need to change gearing with larger tires. gas milage didn't change much, or not a huge difference. it will affect your speedometer and odometer, but I didn't bother with recalibration.
I put larger than stock tires on my '92F150 with 3.08 gears and M5OD. The gas mileage sucked. When I went back to the 235/75R/15's the mileage went up noticeably. Stick with stock. Ford put that size tire on for a reason.
It does seem backwards, but you can actually get worse gas mileage with larger tires. You will be running less rpms on the road, but it takes more force to get the bigger, heavier tires moving. You will also have to give it more gas to get the truck moving the way you're used to.
I have 31x10.50 Yokahoma All-Terrain tires on my 95 F150. They look cool because they have a really aggressive tread pattern, and they make the truck sit up high like a 4wd. They don't rub at all, but they are quite noisy, and the gas mileage is a little worse.
