Pre-Power Stroke Setup
Old Jun 9, 2005 | 09:14 PM
chrisjrosenbohm's Avatar
chrisjrosenbohm
work in progress
1993 f350 7.3 e4od 3.55 228000 miles new heads injectors glows return line kit 5k ago bye bye soup boul strait pipe exhaust had 6 inch lift and 37 inch ssr swampers until 3 weeks ago pulled 4k pretty good with this set up now i put on bushwacker cut out flares and a 3 inch body lift with some big 44 inch super swamper boggers on weld wheels im sure a gear change will follow soon im very happy with my truck it wont be a puller anymore but it will look good ill be buyin a powerstroke for pullin as soon as i find a good one priced right
Old Jun 9, 2005 | 10:54 PM
RawPower's Avatar
RawPower
Chris, you need to creat a gallery. Or perhaps you have a cardomain or superford register thingy elsewhere? if so a link would be great.... Im doing something similar to mine soon...
Old Jun 10, 2005 | 02:11 PM
BikePilot's Avatar
BikePilot
1994 F-250 Ext Cab, 8' bed. Factory Turbo, 4x4, 4.10 gears, E4OD, all stock. Pull a 20' enclosed motorcycle trailer (2k lbs empty, probably carry 1k-2k lbs of bikes, tools etc in it).
looks like this site doesn't like the image host I've been using
here's another host -lets see if it works
Don't have much data other than that. Doesn't seem to use a noticable amount of oil between changes (3k miles). Use shell rotella synthetic 5w-40. Below is what I get for fuel mileage.
Cruise Control set at 70mph (about 2250rpm) --> 13mpg
Cruise Control set at 60mph (about 2000rpm) --> 16.5mpg
Cruise Control set at 55mph (about 1800rpm) --> 21.3mpg
All of the above figures are indicated (as opposed to GPS confirmed etc) and were obtained in very similar moderately hilly conditions on the same day and were tested for more than 100 miles.
Old Jun 10, 2005 | 03:09 PM
justblowin'smoke's Avatar
justblowin'smoke
94 F350 xlt reg cab 156,000 miles 4x4 zf 5sp 4.10 gears 7.3l idi factory turbo 315/75r16 tires on 16x10 rims with no lift
mods pump turned up, k&n air filter
oil pressure dead center in normal never varies until the motor shut off
temp between n and r of normal pulling or not
pyro with crappy (too small) dual straight exhaust soon to be dual 4" stacks with 3" down pipe empty 500-650 loaded 900-1000
boost max 8 psi (stock) soon to have ats upgrade also will have ats intercooler
milage 13 avg
towing 9-10
best 17
oil changed every 5,000 rotella T 15W40 and fram filter leaks and possibly burns about two quarts every 2500 miles
most pulled was about 15000-16000 pounds
runs great only major problem in the year i've owned it was the rear end blow out two weeks after i bought it covered by warrenty
Old Jun 10, 2005 | 03:39 PM
csramsey640's Avatar
csramsey640
1992 F-350 Crew Cab Dually, Fiberglass utility body
197,000 miles
4.10 ratio
New e4od, with HD clutches,TC and large cooler
New Stanadyne Injectors
IP advanced
Straight pipe exhaust
ram air injection
no soup bowel
new front seat (no bragging rights)
10ply Cooper HT's, w 65psi
Class 5 frame hitch.
Average 15.9 mpg
Can hold 65mph on 6% grade
Mystic 15w40
Motorcraft 1995 filter
Baldwin Fuel filter
Most weight combined 17,349 lbs. Pulling a crew cab 1989 dually Chevrolet 6.2 diesel with steel mechanics bed on my 3,100 lb equipment trailer.
Old Jun 10, 2005 | 06:02 PM
DT 466Man's Avatar
DT 466Man
1985 F150 4.9 Np435. Uses 1qt of oil between tanks because the rear main is blown. Doesn't smoke. Can hold 65 with 8k in tow up a medium hill.
What? It was built before the P stroke.
But seriously i've been driving it to school and i'm ready to restore it. So if i can get a job this summer i'm getting a 92-94 F350 4X4 7.3 ZF5. And i'll let you know.
Later
DT
Old Jun 15, 2005 | 10:40 AM
Highmark18's Avatar
Highmark18
92 1/2 F250 Extended Cab XLT 4x4 - 233,000 miles.
ATS Turbo w/wastegate
3" downpipe w/3" straight thru exhaust
E4OD with B&M Shift Improver kit (firms it up nice)
Original injectors, original pump (turned up and advanced)
Digital racepack pyro setup
Change oil every 5000 miles, use Delvac Mobil 1 15-40 ONLY!!
Class 3 Receiver
8 1/2' Western Plow with quick de-tach
265 75 R16 tires at 50 psi
add about a quart every 2500 miles (leaks out the rear main, doesn't burn any)
Soon to get a big intake upgrade (Thanks Dave S. for this idea)
Best mileage ever-16.1 (if I wanted better mileage, I would buy a car)
If this had a manual transmission, it would be the perfect truck-but hey I am not complaining.
MPD56
6.7L Power Stroke Diesel
1192
Oct 31, 2024 04:40 PM
Jesser02EX
35
Jul 14, 2014 12:17 PM
Lowe
Jul 16, 2012 07:49 PM
Leichardti
22
Jan 9, 2012 03:27 AM
Brown Dog
6.4L Power Stroke Diesel
May 23, 2010 09:54 PM
