Testing fan clutch
Old Aug 25, 2004 | 12:34 PM
OldH2oSkier's Avatar
OldH2oSkier
Testing fan clutch
How do you go about testing the fan clutch?
It seems as sometimes it kicks on as it should and other times not at all which is causing my truck to run hot, which in turn then I have almost no power at all,
Being that it is a 89 F250 with a 460 I should have more then enough power.
As it would have it it always seems to happen when I am coming home from the lake and pulling my boat.
Old Aug 25, 2004 | 02:43 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Runs hot idling at a red light, runs cool at highway speed, suspect fan clutch.
Old Aug 25, 2004 | 03:04 PM
haybine's Avatar
haybine
Talking
with the engine OFF and the keys out of the ignition, try to spin the fan by hand. it should spin easy. if any resistance at all then the fan clutch needs replacing.
