I recently bought a 1973 Ford F250. Put in a 429 V8 (rebuilt and painted block blue), that was taken out of a 1969 Mach1. Added 12.5:1 TRW pistons,Erson 1.73 roller rockers,Edlebrock 460 streetmasters intake manifold,Holly 850 2xBrrl carb,Hooker headers,"Cherry bomb" glass packed straight pipes,and it has a "mild" cam. The transmission is a Ford S-95 automatic(rebuilt).
This week I am adding a complete MSD ignition system and a good performance air filter set up. Within the next couple of months I also plan on adding an aluminum radiator,silicon hoses,180 degree stat,dual electric fans,transmission cooler,oil cooler,and a good performance starter. But , before I go any further on the engine and the rest of the truck itself , I need to upgrade my brakes. I have discs up front and drums in the rear. Can anybody please point me in the right direction as far as good brake upgrade packages,etc...website?brand? Also , any tips or advice on things to do to my truck I am all ears.
You should have a Dana 60 in the rear. Going to disk all the way around makes a HUGE difference. Their package has everything you'll need except for the porportioning valve for the master cylinder which is critical you don't overlook.
Thanks man , I'll probally go with that website,prices are decent, and the dana60 rear sounds good too.....do you know of a good website for dana rear?..And what gear ratios for the rear do you reccomend?
He means your F250 came from the factory with a Dana 60 - so you're all set there. As far as gears, what are your driving plans? tire size? cam rpm range?
I've never heard of a S-95 either, where did it come from?
ok.....i'm at about 6500 rpms (redline) , as far as tire sizes ,etc....I plan on droppin it down some and adding drag style rims , fat in the back,etc....Throw ideas at me , i'm all ears.
Um...........you really have no idea what you are doing, do you? My best advice is to read, read, search, and read some more the threads within FTE. That should yield any pertinent advice that you could use.
I'm not a racer, so I'm no good at the details. But I do know you need to decide some basic things before you buy/change anything. Are you planning top end speed or 1/4 mile? What is a S-95 tranny, is it an overdrive? if so, what is the overdrive ratio? Pick some tires so you know how tall they will be. The tire size, cam rpm range, drive style and trans ratio directly affect what rear gears you need.
You may want to check out the 429/460 forum, lots of guys that build these motors hang there...
