3.73 vs 4.30 for 05 CC V10
Long time lurker here!
I am currently negotiating with my dealer to take my 01 f250 CC V10 4X4 on trade for a 2005. The truck will be ordered and optioned out the same as the current one, which is a Lariat. I have added the Brake controller and Upfitter switches, but the problem I am having is deciding whether to go to 4.30's or stay with 3.73's. I tow 9000# for three weeks a year for vacation and approx 6 or 7 weekends during the year - not a lot of towing. I went from a 99 F250 SC V10 4X4 with 4.30's to the 01 with 3.73's. The increase in HP & Tqe from the 99 to the 01 more than made up for the difference in gears, however there were a few times I wish I had the 4.30's in the 01 when I was towing, so with the increase in HP & Tqe for 05, I am wondering whether to go back with the 4.30's, or if the 3.73's would be sufficient for the amount of towing I do. Any comments or insight would be appreciated.
My '00 had 3.73s, and my '01 has the 4.30s, exact same truck except for the color and gears. I didn't notice a whole lot of difference between the two, RPMs are a few hundred more, a little less downshifting maybe,and the mileage was the same. For the weight you're towing I'd get the 4.30s, just for the little extra grunt in getting started.
John
John
on
Originally Posted by vmax
The ordering guide I have for the 05's does not show 3.73s available with the 3v V10. standard gears are 4.10s with 4.30s optional. For your situation 4.10s look to be a good choice.
If this is true I'd go for the 4.10s. I bought mine with 3.73s and I regret it and wish I'd gone for the 4.30. The 4.10s should be a perfect compromise for occasional towing.
i have an 03-250-v10 with 4.30. When i ordered it, the i could have gotten a 3.73 or 4.10 (non-limited slip) OR a 3.73 or 4.30 limited slip. Since i do not tow with the truck, i was looking at the 4.10, but wanted a limited slip.
I went with the 4.30 limited slip. I figured that i would just put a bigger lift and larger tires than i originally planned.
No I figure that have a V10 and 4.30 limited, I should be able to run 35" (with a 4" superlift lift) and all should be fine.
Unless someone here knows differently.
Skygrasper
02-12-2019 11:24 AM
jfs999
08-02-2006 05:55 PM
