For months now I have been trying to figure out why my truck won't maintain speed on the highway. I has to downshift to drive to maintain 70 mph on the slightest of grades or with a small head wind. I brought it to a tranny shop and they said the tranny is perfectly fine but the engine has no power. So I brought it to the Ford Dealer and they can't find anything wrong with it. They are saying that is all the power I should expect from my truck. Here is what I have:
The problem is a heavy truck with a somewhat smallish v8 that doesn't have a whole lot of low end torque. My truck used to be like what you described before I started modifying it.
What size tires are on it? My '89 Bronco W/302 had some trouble exactly like you are describing w/3.55 gears and 33" tires (AOD trans). I switched to 4.10 gears to get it back to normal.
I put 31x10.50" tires on it but it was doing the same darn thing with the 235/75R15 tires that came stock on it. I had the Ford dealer check it out so I am assuming they did a compression check, I will make sure though. It doesn't burn any oil so I don't have any reason to suspect bad compression.
I think I might bump up the timing and put on an electric fan. I already have a K&N replacement filter and catback dual exhaust. I know not to expect much from either but at least its something.
Does anyone know if the OBD-I can tell if the catalytic converter is plugged?
you would more than likely smell very hot metal if your cat was plugged. they tend to get white hot and the motor usually struggles with higer engine speeds due to the blockage.
1)use a vacuum gauge,and look for low vacuum readings.If the air can't get out,it can't get in,hence the low vacuum.
Using a vacuum gauge,and looking for engine vacuum dropping to almost 0 when you give it gas.
2)drill a small hole in the exhaust,upstream of the cat,and measure the backpressure.If the backpressure is excessive,the cat is plugged.
3)drop the y-pipe from the manifold,and take it for a test drive.If the power increases,then you have a plugged exhaust.
I hate to tell you this, but a 5.0 4x4 with 3.55 gears and oversize tires is a DOG. My '94 behaves similarly with all eight compressions over 160. The normally recommended and expenive mods like intakes and exhausts are a total and complete waste of money because they do nothing for low end, only top end, on a short-stroke rev-happy engine. Get 4.10 gears or manually downshift like I do. Second gear is necessary for me to get up CA hwy 330 to my house. Watch your tach. Anything under 2000 rpm is essentially lugging that engine. I am thinking of getting a chip and maybe that will help.
