Stuck in 4WD
Old Jun 8, 1999 | 07:07 PM
Jon's Avatar
Jon
Stuck in 4WD
My 95 XL model explorer seems to be stuck in 4WD. Anyone heard of this problem and if so what is the fix?
Old Jun 9, 1999 | 11:05 PM
Pastmaster's Avatar
Pastmaster
Stuck in 4WD
Try backing up. some four wheel drives won't go out of 4wd without backing up
Old Feb 19, 2000 | 12:12 AM
ExplorerEB96's Avatar
ExplorerEB96
Stuck in 4WD
always when you use your 4wd
place your truck in 4wd while either stopped or rolling in neutral. always place truck in 4wd first before putting it in 4wd low. never use 4wd low for long periods of time..(save it for when you are serious stuck problems, mud, and sand) to take your vehicle out of 4wd place truck in neutral again and back up at least 5 feet to unlock the hubs.. you should feel a slight kick... that is the hubs unlocking... sometimes the hub sensor is stuck or malfunctioning..if you feel that kick and your truck feels like its in 2wd(you should notice a difference) then you are in 2wd just get the sensor checked out
Old Feb 19, 2000 | 05:55 PM
hilltopjo's Avatar
hilltopjo
Stuck in 4WD
bboone52
Nov 9, 2011 08:42 AM
SCtruckgirl
Apr 6, 2010 05:57 PM
Pro DIY
Dec 29, 2009 04:30 PM
rknight34
1978 - 1996 Big Bronco
Feb 17, 2005 06:24 PM
emboyd
May 11, 2002 12:15 AM
