Sponsored by: Auxito
4x4 won't engage
Old Aug 23, 2004 | 11:36 PM
RacerLT250R's Avatar
RacerLT250R
Exclamation 4x4 won't engage
i have a 97 f-150 4.6 auto with manual transfer case.......anyway when i shift the t-case from 2 hi to 4hi the t-case feels like it engages and it does b/c the front drive shaft turns.....the lights on the dash don't come on...but the real kicker is that some times the t-case and the front diff engage and the lights come on and i have 4x4....im not sure if its a vaccum problem or front diff shift fork thats busted...i have also heard the switch on the t-case that tells the front diff to engage will fail ..but any help would be greatly appreciated.
Old Aug 23, 2004 | 11:41 PM
fordguy1960's Avatar
fordguy1960
his sounds like you have the opposite problem to me !!! mine won't come dis engage !!
Old Aug 24, 2004 | 12:16 AM
RacerLT250R
sometimes disengageing the t-case and while travel forward at say 5-10 mph whip the steering wheel back and forth .....i had the same problem with myy 96 ford explorer...the automatic hubs stuck on occasion
Old Aug 24, 2004 | 09:22 AM
Tom's Avatar
Tom
The F-150s don't have automaic hubs. There is a vacuum operated disconnect in the front differential.
It's probably a problem with one of your solenoids, or maybe a vacuum hose is plugged.
Old Aug 24, 2004 | 11:16 AM
RacerLT250R
ur right the f-150's have a vacuum operated center disconnect... i checked the vacuum lines and the solenoids both operaterate fine when i do get the axle to engage...4 LO works fine but the LOW light doesn't come on.....4 HI works but i have to wiggle the floor shifter back and forth....is there a switch or contact patch that can be clean with out tearing the transfer case part...the transfer case shifts perfectly it just doesn't engage the front axle....am i correct in believing it is a switch in or on the t-case not making contact that is causeing my problem??
Old Aug 24, 2004 | 01:46 PM
dpatrick's Avatar
dpatrick
i have a 99 expedition and the 4 awd switch does not work. checked the fuses under the hood but they were good. can you help. first time to own a 4x4
Old Aug 24, 2004 | 02:29 PM
Tom's Avatar
Tom
First of all, the fuses for the 4x4 system would probably be located in the fuse box in the passenger compartment. I believe they are under the instrument panel on the drivers side, check your manual.
RacerLT, there is an indicator switch that I believe is mounted to the transfer case somewhere. The shop manual is very vague in this respect, but I'd try replacing it. The instructions for replacing the switch are simple: unplug it and unscrew it. Look for a sensor along the linkage for the transfer case and on the case itself, it shouldn't be to hard to find.
