Sponsored by: Real Truck
Changing tire size speed sensor problems??
Old Aug 23, 2004 | 08:21 PM
woody1003's Avatar
woody1003
Exclamation Changing tire size speed sensor problems??
I have a 2000 F-350 SD 4x4 with 3:73 axles. It has a tire size of 265-75-16 E- range tires. I wanted to switch to a more affordible tire size of 235-85-16 e-range , since the truck will be used for plowing in NE I don't mind them being taller and thinner. Will be changing all 4 with agresive snow tires. But the dealer says that by changing the tire size would throw off the computer speed sensors. So I see by other post people are always going to bigger tires, I would like to know if their has ever been a problem with that giving bad info to computers. And is there a way to reset the computer for the new tire size. I have 4 wheel ABS I don't want to do somthing that is unsafe would not be worth the money saved. Thanks for any help or suggestions
Old Aug 23, 2004 | 08:31 PM
Tlattin's Avatar
Tlattin
There is a Tru-speed module by Superlift that hooks in-line with the speed sensor wire on its way to the ABS that corrects the signal to different tires sizes. It can store two different sizes and be changed with the flick of a switch. I got mine at 4wheelparts, also offroadwarehouse. Easy one hour install. Changing gears makes no difference as the magnetic sensor picks up outside the ring gear. Tru-speed corrects tire size for ABS, shift points, speed, and odometer.
Old Aug 23, 2004 | 08:32 PM
wvabeer's Avatar
wvabeer
your dealer can change your speedo settings mine did it just took a few minutes
Old Aug 23, 2004 | 08:43 PM
woody1003's Avatar
woody1003
Thanks-- That true speed add on, what tire sizes is it pre set for? Or can I dial in a size.
Old Aug 23, 2004 | 08:46 PM
Tlattin's Avatar
Tlattin
You set it via an adjustment screw on the side for the two settings. It is infinately variable to tire sizes. If you switch to snow tires in the winter, the two settings are nice to avoid dealer trips for OBD changes.
Old Aug 24, 2004 | 12:14 AM
SoCalDesertRider's Avatar
SoCalDesertRider
Woody,
Guess what, you're in luck today... 265/75-16's are the SAME DIAMETER as 235/85-16's, so there is NO NEED to do anything with your speedometer .
Old Aug 24, 2004 | 07:32 AM
woody1003's Avatar
woody1003
Smile
WOW-- The tire guy suggested that size I didn't know they where the same diameter. The 265s in load range E cost about $180 each, the 235s in E cost about $100 . Thanks again for all the info
Old Aug 24, 2004 | 11:57 AM
VintageRR's Avatar
VintageRR
265*.75=198.75
235*.85=199.75
1mm is close enough for Government work!
Old Aug 24, 2004 | 12:08 PM
{OF}Smiley's Avatar
{OF}Smiley
No matter which way you go with the tires you'd better think about taking your truck to a different dealer for service. The speedometer calibration setting in the computer can accomodate quite a large difference in tire heights. If I remember correctly from about 28 to 36 inches. They use the tire's circumference and then a calibration table to determine the proper setting. If you dealer was not aware of this setting nor how to set it he is not a dealer to use.
Old Aug 24, 2004 | 04:03 PM
Fredvon4's Avatar
Fredvon4
I agree, this is a standard and easy function of the PCM programing and any dealer that does not know how, or charges more than $15-25 for this service, is to be shuned, avoided, ridiculed, chastized, and flogged unmercifully
Yes that is how I really feel!
itry2fly
Jan 10, 2013 07:29 PM
broncman
Sep 1, 2008 03:29 PM
robertm
2004 - 2008 F150
Aug 27, 2005 02:33 PM
jfralph
Nov 26, 2003 03:46 PM
72stepside
1997 - 2003 F150
Sep 6, 2001 03:57 PM
