460 Exhaust Setup
Old Aug 23, 2004 | 07:53 PM
oricle's Avatar
oricle
460 Exhaust Setup
Right now I have a 91 F250 with a 460. Basiclly all is stock, and I have it running to 1 muffler with dual outlets. The headers connect to a single cat, and the cat goes to the muffler. Is it possible to go to dual mufflers, and would it be wise for the money, or would I not notice a big power differnce, or would you suggest just going with a aftermarket Muffler? Would swapping this or swapping the headers, or a performance chip be the best bang for the buck?
Old Aug 24, 2004 | 02:23 AM
kens64's Avatar
kens64
Headers would probably be the best bet for power gains.
Old Aug 25, 2004 | 11:04 PM
kevinrf250's Avatar
kevinrf250
Go with headers, and a true dual exhaust. This is what I have on my 460 and I like it very much. If you have any questions about it I will try to answer them.
Old Aug 26, 2004 | 01:48 AM
oricle's Avatar
oricle
Kevin did you go to a local shop to get the exhuast done, or did you order it pre built? If so could you give me a site where they had it.
Old Aug 26, 2004 | 11:05 AM
snowmobilerfreak's Avatar
snowmobilerfreak
Get it built at a shop, that way you save money....you get to pick your own mufflers....and you get to tell them how you want it.
Old Aug 30, 2004 | 04:21 PM
kevinrf250's Avatar
kevinrf250
I had it built by a shop.
Old Sep 1, 2004 | 01:38 AM
351M's Avatar
351M
Hey Kevin, on you're truck is the big flange right after the O2 sensor still on yer exaust system? It is still on my '90 but both sides are dual pipes. Looking at that I am gonna guess that is acts as an H or X pipe of sorts? Would I be wise in getting rid of it and just putting the O2 sensor in one of the pipes?
Old Sep 1, 2004 | 02:38 PM
kevinrf250's Avatar
kevinrf250
There is nothing left of the factory exhaust on my truck. I think that it is smart to have an H-pipe in front of the O2 sensor so that it gets a more accurate reading. Hope this helps.
Old Sep 1, 2004 | 06:00 PM
351M's Avatar
351M
The O2 is welded between the 2 pipes and the flange where the converter was is acting as a crossover pipe.
1985 Bronco
1978 - 1996 Big Bronco
Dec 28, 2015 12:09 PM
cjben
Sep 17, 2015 04:02 PM
BLaCkSiLo
Exhaust Systems
Feb 18, 2004 06:59 AM
intimidator7393
Exhaust Systems
Nov 9, 2003 08:06 PM
fordpower460
Exhaust Systems
Nov 27, 2001 03:27 PM
