Sponsored by: Auxito
2000 F150 brake light
Old Aug 23, 2004 | 02:21 PM
Ted2000F150CC's Avatar
Ted2000F150CC
Question 2000 F150 brake light
I have a question about the brake light bulb on my 2000 F150 Crew Cab. The light is not working and needs to be replaced. How do I get to the bulb? I looked under the truck and can see where the bulbs located. There is a small hole there, not big enough to get my hand through. Before I go do something stupid, could someone tell me the correct way to replace the bulb? Any advice would be greatly appreciated. Thanks, Ted
Old Aug 23, 2004 | 03:41 PM
tkondro's Avatar
tkondro
When I replaced my bulb, I took off the whole brake light cover. It's only a couple of screws to take out. Put the end-gate down and you should be able to see the screws. Be sure not to drop the screw or you will probably require a magnet to get it.
