which engine I have
Old Aug 23, 2004 | 12:33 PM
rsg36's Avatar
rsg36
which engine I have
Hi, I bought a 69 F250, serial shows the engine should be 360, but it doesn't match with the engine. The engine is a V8, holley 4bbl carb, mechanical fuel pump, valve covers are blue with "powered by ford" on them, oil filter screw on type not canaster, please let me know if there is a way of nailing down which engine is it. Thanks
Old Aug 23, 2004 | 12:36 PM
BB's Avatar
BB
Hi! Welcome to the site!
What makes you think it's not a 360 aside from the 4bbl?
Old Aug 23, 2004 | 01:10 PM
rsg36's Avatar
rsg36
hi, the oil filter is the screw
Old Aug 23, 2004 | 02:01 PM
Mike G's Avatar
Mike G
360's had the screw on oil filter... If the intake manifold extends half way under your valve covers and the plugs are angled to the center ( \\ // ), then you have the 360 or a member of the FE engine family in there.
Welcome aboard!
--Mike
Old Aug 23, 2004 | 03:24 PM
FordManStan's Avatar
FordManStan
another easy way to tell if its an FE is the 5 bolt valve covers with three bolts on top and two on bottom
Old Aug 23, 2004 | 04:06 PM
rsg36's Avatar
rsg36
hi, the oil filter is not the canister element filter style,
Old Aug 23, 2004 | 04:20 PM
Mike G's Avatar
Mike G
The oil filter screws on to the oil filter adapter which is bolted to the motor. The filter will be either mounted vertically (cars and 4x4's) or horizontally (trucks). It is located down low to the right of the fuel pump. Sorry, I know what you mean by canister filter, but can't say I've seen one on anything newer than 1960. If you still think we are on the wrong track, you will need to pull a few numbers off the motor, say the manifold or head casting numbers.
--Mike
Old Aug 23, 2004 | 05:10 PM
rsg36's Avatar
rsg36
Hi, I think you're correct, the filter mounts horizontally, I have the airintake manifold numbers, I'll send it you later today, the cast number is either 501 or 105 depends on which direction you read it. Also I'm wondering about the carb being 4bbl Holley 4160. Thanks for your help
Old Aug 23, 2004 | 05:15 PM
BB's Avatar
BB
Ah, the mirror image block! You got a late model FE, need to check the stroke of the crank. Do a search in the FE forum for "stroke".
Old Aug 24, 2004 | 10:30 AM
rsg36's Avatar
rsg36
Hi, Intake manifold has the following numbers 5751807 83K, any idea what it means. thanks,
Old Aug 24, 2004 | 11:10 AM
BB's Avatar
BB
Damn that's an old intake, it's off a '58.
Old Aug 24, 2004 | 12:25 PM
rsg36's Avatar
rsg36
do you have the listing for those casting numbers to use, thanks
Old Aug 24, 2004 | 12:39 PM
BB's Avatar
BB
Nope, sorry there is no listing. Wish it were that easy.
Sounds like your engine is a combination of parts. What's the head casting numbers? They are right between the center two spark plugs.
Old Aug 24, 2004 | 01:47 PM
rsg36's Avatar
rsg36
hi, plugs 2&3 or 6&7, thanks,
Old Aug 24, 2004 | 02:00 PM
BB's Avatar
BB
Yes.
Each head will have it's own casting number like this:
