Stuck wheels on 2002 F150
Anyone have a trick for removing the wheels off a 2002 F150? The aluminum rims have corroded to the hub. I managed to get 3 out of 4 of them off after more banging and dropping than I would have liked to do. The passenger front will not budge. I've tried wedging a 4x4 between the frame and rim and turning the wheel. Whacking with every size of rubber mallet, standing a 4x4 against the rim and hitting with a sledge hammer and prying against the caliper and it still won't come off. Truck has 42,000 miles on it and the wheels have never been off. Seems that Ford forgot to coat the back and hub hole of the rims with anything to prevent dissimiliar metal corrosion.
Try spraying some sort of penetrating oil (i.e. WD-40) and letting it soak for a little before trying to remove the wheel. It is important to remember tahat after you remove the wheel to clean off oil residue and overspray (related to the penetrating oil) off of any and all brake components and the lugnut seating surface on the rim. To prevent any future stuck wheels, a light coat of neverseize on matting surfaces should prevent any type pf future corrosion.
reamer
02-17-2007 04:59 PM
