Sponsored by: Auxito
transmission shifting hard
Old Aug 23, 2004 | 01:17 AM
mike_65's Avatar
mike_65
A couple of months ago we discussed having larger tires installed and no need to reflash/ calibrate speedometer. Well I went from 265/75/16 to 285/75/16. Everything seem to be fine. Finally went on vacation and while driving on the interstate, with the cruise engaged, truck gets under a load going up a hill and transmission shifts really hard. It goes from 2000 rpm to 2600 rpm to 3000 rpm, kinda like it is shifting through two gears instead of one. Any suggestions? I have a 2001 sc 4x4 5.4l
Old Aug 23, 2004 | 10:20 AM
FourthFordTruck's Avatar
FourthFordTruck
From what I read, it's not that there is no need to reflash/recalibrate the
speedometer, it is that there is not a way to reflash/recalibrate the speedometer electronically. You have to change something out in
your transmission or differential, I'm not sure which.
I think it's a gear or wheel. I put bigger tires on mine and it
runs faster now than the speedometer shows.
Old Aug 23, 2004 | 02:16 PM
BillyBob69's Avatar
BillyBob69
I don't know what year it was added in...but on my 02 with the 4.6 Triton, I read in the manual that it has a "learning" transmission. You can reset the tranny by disconnecting your battery to reset the puter, then just hook it back up. Your tranny will begin to "track" your driving habits and begin to set itself to follow the way you drive. Althoug it does say it takes a few hundred miles to get into a good solid sync.
Old Aug 23, 2004 | 02:54 PM
FourthFordTruck
That's cool on the learning transmission.
Old Aug 24, 2004 | 09:02 AM
BillyBob69's Avatar
BillyBob69
I never knew that Ford even had anything like that until I read my manual on the truck I just bought. So I did the reset and I did notice a different shifting pattern. Hopefully it wont take that long.
SuperDutyScaler
Mar 5, 2012 12:48 PM
t/c hobo
Dec 31, 2006 09:21 PM
Motown Fire
19
Apr 22, 2005 06:37 AM
01HARLEY
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 5, 2005 07:38 AM
Jerzy
Jul 27, 2004 02:40 PM
