Antenna
Old Aug 23, 2004 | 12:03 AM
mrladylover1469's Avatar
mrladylover1469
Antenna
Can anyone tell me how to get to the antenna in a 97 explorer limited? My power antenna does not work and I think someone might have unhooked it(previous owner) because their is a black round antenna wire coming from that direction which I don't belive is suppose to be their.
Thanks
Old Aug 28, 2004 | 12:51 AM
mrladylover1469
I have fixed the problem of hooking the antenna up but now that its all plugged in and has power the antenna won't go up and down. I can here it turning and trying to go down but nothing happens. Can anyone help? Thanks.
Old Aug 29, 2004 | 09:06 AM
Options's Avatar
Options
My 98 xplorers antenna did the same thing. I could hear the motor running but it wouldnt go down.
I had to buy a new antenna mast at Ford for 34 bucks and replace it. The teeth get stripped on it. Now it works great. Gently pry off the the black plastic cover around the antenna base. Undo the screw and the whole antenna mast pulls out.
Search the site for replacing the antenna. If you have anymore questions write back.
Old Aug 31, 2004 | 12:53 AM
mrladylover1469
Where did you get your antenna mast from? I'm not sure where to look. Did you look for the cheapest prices? I am really short on cash and I would like to fix this. So is it the mast I need or somthing else? What kind? I looked around a little bit and their are different sizes(lengths). Any help would be great. Thanks
Old Aug 31, 2004 | 05:45 PM
Options's Avatar
Options
I only could find the part at Ford. Ebay had knock offs and autoparts stores didnt have them. Call your local Ford dealer. About 30 bucks.
Old Aug 31, 2004 | 05:50 PM
Options's Avatar
Options
Also, yes you only need the mast. Search the forum for antenna removal or replacement to get instructions.
Old Sep 1, 2004 | 02:55 AM
mrladylover1469
Thanks for your help!
Dyllan78
Mar 29, 2012 11:08 PM
86sujaguar
Apr 10, 2008 10:00 PM
RagdollRacer
Feb 16, 2007 06:07 PM
THEBOOGIEMAN
Offroad & 4x4
Mar 26, 2006 10:22 PM
taxabel
66
Oct 10, 2004 12:59 AM
