1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
GEM Module source
Old 08-22-2004, 08:46 PM
slickwilly's Avatar
slickwilly
slickwilly is offline
GEM Module source
Anyone have a good source for a GEM module & fuse panel? Mine are toast.
Thanks.
Old 08-22-2004, 09:46 PM
High_Horse's Avatar
High_Horse
High_Horse is offline
What year, what vehicle, what options, is it custom? Helpful info for a reply. Not ******* ya dude, just asking. Blindly, I would say check a good recovery yard. By a good one I mean one that has a computer so if it doesn't have what you want, it can get online and find it at another. I don't believe a GEM mod is specific, but usually the yard can tell ya, check the connectors to be sure. Count and check your wire colors and match them also. Don't take the yards word of "don't worry it will fit", start worrying because it usually doesn't. Crossreference your wiring and the one you are getting.
Some yards are pick and pull,....but some will pull for ya, these are generally good ones because they don't want people hacking up there profits.
Old 09-09-2004, 04:05 PM
mwtomli0's Avatar
mwtomli0
mwtomli0 is offline
my 97 expd sometimes wont start it cranks then stalls. this seems to only happen when it rains. any idea what it could be
Old 09-09-2004, 07:15 PM
High_Horse's Avatar
High_Horse
Actually this should be a seperate thread, but that's ok, I'm not a mod......lol. I have a 97 also, w/remote start, and it doesn't always start (1 of 200 or so), but mine fails on first cold start. It will start on the next crank though.
Ok, first a couple questions: How many miles are on it, what size motor, does this do this on cold morning start or when its warm?
An initial recommendation may be the DPFE unit, located on the driver side of the throttle body. Its a pot mettle piece about the size of a playing card with two vacuum lines coming in behind it. Check the holes in the unit that the vacuum's connect to, they may be corroded, constricting flow. Just replace the unit, the replacement is plastic and won't corrode. Another possibility, depending on mileage, is spark plugs, they are generally only good to around 100-120k. These are just a couple to start with, with more info from you maybe we can be more specific.
Old 09-09-2004, 10:46 PM
mtitech's Avatar
mtitech
mtitech is offline
There's a supplier in Florida that has these for $129. Be sure to order one for your specific year due to the differences in the model options that these control. I don't think we are supposed to post links so do a Google search for ECU Tec Parts and you should find them.
Old 09-13-2004, 09:02 PM
slickwilly's Avatar
slickwilly
mtitech, Thanks for the Info. I searched and ended up at the dealer for mine. I also had a leaky windshield and had it resealed however it still leaks. So a word of caution make sure the leaks get taken care of.
Old 09-14-2004, 05:41 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Try replacing your AIC.
by slickwilly Anyone have a good source for a GEM module & fuse panel?
How did you toast yours?
by mtitech I don't think we are supposed to post links...
Sure you can! Just be mindful not to post links that are direct competitors to the Online Store or the advertisers here. They pay the bills so that we can all use FTE for free!
Wrecking ball
07-24-2021 02:08 PM
misty1
10-16-2016 08:14 PM
Glenn Fisher
1999 to 2016 Super Duty
03-29-2016 11:59 PM
jlcparis
04-23-2010 02:48 PM
sleepyhead416
03-07-2010 06:17 PM
Quick Reply: GEM Module source
