overdrive lite flashing
Old Aug 22, 2004 | 08:16 PM
robraz's Avatar
robraz
95 explorer w/ 4.0 liter engine auto, wife was driving and it started to flash and i cannot turn it off w/ button , also truck w/ not shift into high gear now, need help asap...thanx
Old Aug 22, 2004 | 09:05 PM
Clubwagon's Avatar
Clubwagon
You will need to at least have the codes read. The OD light flashing means the transmission has set a DTC (Diagnostic Trouble Code). Most likely there is something wrong with the transmission or its electronics. I would suggest having it checked by a reputable transmission shop.
Good Luck.
Steve
'95 Clubwagon XLT
Old Aug 25, 2004 | 05:43 PM
SgtJoe's Avatar
SgtJoe
Just another note, the transmission will go into a limp mode when the O/D light flashes. You may also notice hard shifting.
Old Aug 29, 2004 | 07:15 AM
Hunt1's Avatar
Hunt1
O/D light flashing
Hey I just had this happen with my 01 F250 with the 7.3. Took it to the shop and they said 4th gear was gone. 1200.00 to fix. Best of luck!
