temperature indicator
Old Aug 22, 2004 | 08:14 PM
Bob Crain's Avatar
Bob Crain
Had the dash apart to take out the old dash pad and put in a good one
in when I put it all back togather and turned the key on the temperature
indicator went all the way to hot with out it running. Help
1972 F100 still working on the wireing for the 77 steering column
No horn or turn signal lights work horn works but not at the
steering wheel.
Old Aug 22, 2004 | 08:42 PM
dddk's Avatar
dddk
Hi Bob
I am not great a wiring,but it sounds like you might have nicked a wire and it is grounding out.Thats how i check the gauges to see if they have failed or if the sending unit is no good by taking the wire off the sending unit and ground it out.Then if the gauge goes to full or in your case to hot, then the sending unit failed.If the gauge doesn't move its no good.Hope that help you! Oh that with the in the on position.As for your other problems i am not sure , i had a friend do that stuff for me.
I will be talking to you soon! dddk
Old Aug 23, 2004 | 07:50 AM
Bob Crain's Avatar
Bob Crain
gauges
Hi dddk will check the wires out today
Old Aug 23, 2004 | 04:27 PM
6t9er's Avatar
6t9er
with the gauge problem you should check the wiring and then check the sender incase it isn't working corectly. af far as the horn make sure that the steering shaft is grounded, i had the same issue with the horn and it turned out the shaft inside the column, the one the nut goes on that hold the steering wheel, wasn't making a good ground so i just grounded it like it was in the truck i pulled my column from, wire going from one side of the rag joint to the other. wiring's a tricky issue, haven't been able to get mine to work correctly either, when i do though i'll let you know how it goes together, currently only my right turn and brake light work but both fronts work.
Old Aug 26, 2004 | 02:07 PM
Bob Crain's Avatar
Bob Crain
Temperature indicator
Hi All we Found the problem with the temperature indicator
Had the coil wire and the temperature wire back wards
All works good now.
