300 ci 6
Old Aug 22, 2004 | 03:52 AM
ken phelps's Avatar
ken phelps
Question 300 ci 6
what is the easiest way to tell if i have 3oo ci block.
i have just bought a 72 ford falcon and according to rego papers its capapacity is 325ci as the 250 was the biggest 6 used in the falcons its got me curiouse so any specs and info would be appreciated
Old Aug 22, 2004 | 08:48 AM
holland501's Avatar
holland501
Unless someone has done a swap, 240ci. was the only 6cyl. used in cars in 1972.
Old Aug 23, 2004 | 02:24 AM
Ford_Six's Avatar
Ford_Six
Well, with a Falcon, if the radiator has been relocated, and the engine almost touches the firewall and radiator support, you have a 240 or 300-6. Other than that, it is either a 200 or 250 small six.
Old Aug 23, 2004 | 09:41 AM
oldhalftons's Avatar
oldhalftons
200 was the biggest six put in american/canadian falcons, with most getting the 170.
The 240 was only used in galaxies for a couple years (64-65 I think)
the easiest way to tell at a glance is, the 240/300 six
has a valve cover with 6 large evenly spaced bulges on the passenger side.
The 144/170/200 (and even the 250 but its a motor thats alot different from the other small sixes) has a valve cover that has several bulges on the sides of the valve cover.
Old Aug 23, 2004 | 09:50 PM
63redtudor's Avatar
63redtudor
The smaller I6's (144/170/200/250) have a cast-on intake log. The 240/300 series motors have a detachable intake (& are bigger).
Edwin
Old Aug 26, 2004 | 06:20 AM
ken phelps's Avatar
ken phelps
thanks for all your replies i now beleive it is the 250ci 6 my rego papers are wrong.
Here in australia they still use a varient of the old 250 but these days its called the 4.0l dohc 24 valves mpi with or with out turbo
and prior it dropped down to 3.9l ohc 12valves mpi this was in 1988
and prior to that we had alloy head crossflow 2bl carburated or efi 1983 this replaced cast iron crossflow 1bl carb 1976
prior to that we ran the 250 with inlet manifold cast as one peice to the head or the 2v with separate in let manifold
spacegrass
Nov 18, 2014 05:12 PM
Ranchero_Boy
Feb 2, 2014 08:03 PM
jmm
Apr 13, 2008 04:26 PM
slim_falcon
All Things Towing
May 26, 2003 02:25 PM
