Exhaust stud problems
Old Aug 21, 2004 | 10:21 PM
sir69ford's Avatar
sir69ford
I have a 1969 ford f-100 ranger with a 390 I was able to get the exhaust studs out. I can not find replacement studs can someone help me please?
Old Aug 21, 2004 | 10:39 PM
BB's Avatar
BB
Did you look at the nuts and bolts in the "HELP" section of your auto parts store? Or maybe try a muffler shop, they replaced a stud in mine when I had some work done.
Old Aug 21, 2004 | 10:55 PM
sir69ford's Avatar
sir69ford
I have tried the (help) section I have bought 2 sets there neither one worked. I have not tried the muffler shop I am going to have some work done so I will give that a try thanks that helps
Old Aug 22, 2004 | 04:06 AM
Mike W's Avatar
Mike W
How about some stainless steel threaded rod? I hate rust.
Old Aug 22, 2004 | 09:07 AM
orich's Avatar
orich
You can go to any hardward store and get grade-8 bolts for it.They look yellowish.. Make sure the upper bolts don't come out pass the threads or you may never get them out once the threads rust that are sticking out. Note stainless steel bolts are only grade-5.... my 2cents
orich
Old Aug 22, 2004 | 10:25 AM
fordloverf2501970's Avatar
fordloverf2501970
find out which store in your area carries nuts and bolts, farmland ? farm and fleet ? defintly not walmart. the help sections of most part stores dont carry boltsw and nuts, keep looking you will find them, i get all mine at farmland.
Old Aug 22, 2004 | 10:52 AM
sir69ford's Avatar
sir69ford
Orich What do you mean ?Make sure the upper bolts don't come out pass the threads? Are you talking about all thread? or are you talking about studs?
Old Aug 22, 2004 | 11:00 AM
sir69ford's Avatar
sir69ford
Ford lover Just any farm supply you think will have that exhaust studs? or should i look just for the farmall?
Old Aug 22, 2004 | 01:56 PM
fordloverf2501970
any store that has a bolt selection would have studs, farmland store up here has a complete line of nuts and bolts in every grade and size. i replaced almost every bolt stud and nut for less then 2 dollars a pound, i think my entire engine bolt set all in grade 8 was about 4 bucks
Old Aug 22, 2004 | 07:10 PM
orich's Avatar
orich
sir69ford, threads are threads if there sticking out right in the open. I've seen alot of cracked exh-manifolds on the right side from that heat shield for the hot air pickup pipe. On trucks that pull a trailer or camper when in very warm weather. Some People remover or even drilled holes in them to cool it some trying to keep them from cracking. If you can try to use a graphite base lube on the threads, this will add to the ease the next time you have to remove them if you have to. You should check these about 8-10,000 miles to make sure there tight. this will help from burning out a exh-manifold gasket if your using them.. my 2cents
orich
Old Aug 22, 2004 | 07:26 PM
BB's Avatar
BB
I thought we were talking about the two studs on the outlet?
Old Aug 22, 2004 | 08:59 PM
orich's Avatar
orich
Oh where the manifold head pipe connect nope! The 8 manifold bolts is what. I've been talking about.. Funny how we can all read the samething and 1/2 of us get a different idea of what someone is saying..
orich
Old Aug 22, 2004 | 11:46 PM
Faithful Old Road Dog's Avatar
Use anti-sieze on the threads before you put the nuts on.
Old Aug 23, 2004 | 12:25 AM
docholiday72tx's Avatar
docholiday72tx
When I used to run FE engines I had a bad problem with the manifolds leaking and the bolts breaking off in the heads. I took my electric drill and bored the threads out of the heads and run a bolt all the way through and used a lock washer and nut on the back side. It seemed to cure all my problems and was much easier to deal with. I bought the yellow looking grade 8 hard ware from tractor supply company and paid probably 4 bucks. I think the reason people got confused is ordinarily studs are used to connect the lead pipe to the manifold and bolts are used to connect the manifold to the head. In sir 69's original post he asked about studs, so people naturaly assumed the bottom of the manifolds. For what it's worth, I don't think studs on the top are a very good idea because of the way that the bolts tend to get stuck. If you do go back with studs, use the anti sieze that was suggested.
Old Aug 23, 2004 | 03:57 PM
numbertwentynine's Avatar
numbertwentynine
e-mail me I'll send you some I had to buy 100 of them when I bought them.
