Bronco II Ford Bronco II
Engine timing
Old Aug 21, 2004 | 07:34 PM
ATVBronco's Avatar
ATVBronco
Engine timing
I want to experiment a little with the initial timing on my '90 2.9l. To time the engine, what plug and where is it located that is supposed to disconnected to set the timing? Also, has anyone tried a little less timing than stock 10 degrees for a little more low end power, or will the computer negate any changes to the initial timing anyway? Mine is a 5 speed with 235 tires and 3.73 gears, would like a little more low end torque - changing to 4.11's isn't gonna happen!!
Old Aug 22, 2004 | 06:54 PM
Ken00's Avatar
Ken00
Front passengers side is the #1 plug, to get base you'll need to pull the spout connector, it's in a wiring harness close to the distributor.
I don't think that will help with power.
Old Aug 23, 2004 | 11:17 AM
mrshorty's Avatar
mrshorty
On my '87, the SPOUT connector is kind of hanging over the passenger valve cover. Yellow wire with green stripe, I think.
mtbnski
Nov 10, 2014 08:16 PM
LARIAT 85
Feb 23, 2014 03:29 PM
Renard
Jan 6, 2014 10:04 PM
isenegger
15
May 15, 2010 10:57 PM
Anafiel
Feb 15, 2010 06:27 PM
