Offroad & 4x4
Will An Add-a-leaf Work?
Old Aug 21, 2004 | 10:25 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
I Have A 93- F-250 That Is Stock In Regards To Suspension And Wheels/tires. The Problem Is That The Front Is Quite A Bit Lower Than The Rear. The Front Leafs Appear To Be Bending Slightly Downward Kind Of Like A Sad Face ( , Not Quite That Extreme Though. I've Looked At Other F-250's And Noticed That The Springs Are Mostly Straight Across Or Arched Upward. Question Is: Will An Add-a-leaf Correct This Problem And Level The Front End Or Will New Springs Be Required. As It Sits, The Front End Appears To Be Approx 2" Lower Than The Rear.
Old Aug 21, 2004 | 05:43 PM
teds74ford's Avatar
teds74ford
Yeah, but then your TTB alignment will probably be off, and wear tires funny. You might need pivot brackets to make it right.
Old Aug 21, 2004 | 06:12 PM
proeliator's Avatar
proeliator
And It Will Ride Like A Load Of Bricks.
Old Aug 22, 2004 | 09:22 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
It Rides Like A Brick Now, Could It Possibly Get Worse? I Was Thinking Of New Springs With Multiple Thinner Leafs. Thanks
Old Aug 22, 2004 | 11:44 AM
rebocardo's Avatar
rebocardo
I would just order a new set of leaf packs.
The problem exists mostly in the top three leaves in a spring pack when they have a negative arc, mostly from overloading. Adding in a lift leaf will do little to correct the problem and sooner or later that weak spring will break.
imo, If you are going to add a lift/add-a-leaf then make sure it extends beyond the eye springs. So do, some do not.
Old Aug 22, 2004 | 12:25 PM
fishmanndotcom's Avatar
fishmanndotcom
i would make a set of shackles that are 1-1.5" longer for the front! but that's just me! new spring packs are not worth an extra inch!
-cutts-
Old Aug 22, 2004 | 12:34 PM
BSHORT's Avatar
BSHORT
Top Answer: 5
Good Idea..i Think Trailmaster Makes Longer Shackles...any Ideas As To That?
Old Aug 22, 2004 | 12:40 PM
proeliator's Avatar
proeliator
Yes It Can...Much Worse In Fact. New Springs With Multiple Thinner Leafs Will Help Your Ride Problems And Your Height Issue.
Old Sep 1, 2004 | 11:49 PM
Hounddog1's Avatar
Hounddog1
Hey there,
I too had a '93 F250 that had a sagging front end. After much research and talking to others with the same problem, I decided to go with the advice that fit my wallet the best.
I bought new F350 springs and F350 rear lift blocks and put those in. The F350 springs shot the front end up 4.5 inches and to level the truck out, I threw in the F350 4" rear lift blocks.
I was politely discouraged not to add an "add-a-leaf" as ride would sacrfice - now adding 1 ton springs doesn't help to keep the coffee in the travel mug , however the ride seems to dampen much better on the bumps. Before the truck would jump all over the road.
I just completed this conversion 2 days ago and will be taking the truck in for a wheel alignment. I'll post on if it's a success or not.
Old Sep 3, 2004 | 11:37 AM
ivanribic's Avatar
ivanribic
I was also going to suggest going to F350 springs. Don't know why Ford used the negative arch springs in the F250's but they suck big time. Check you local wrecking yards . . . bet you can get a pair of front springs from an F350 for $50-$80 and be ready to roll.
Old Sep 3, 2004 | 11:43 AM
fishmanndotcom
i've got a set of 350 springs down in the barn anyone can have if they want them
-cutts-
Old Sep 3, 2004 | 02:39 PM
littlebig(truck)man's Avatar
littlebig(truck)man
I'll take 'em -how much for shipping, Cutts?
Old Sep 3, 2004 | 07:28 PM
bremen242's Avatar
bremen242
actually, the IFS F-250 springs don't actually have negative arch. They just look like it
Seriously though, gas springs have a positive arch (like 1/2-3/4"). The diesel springs I have on mine are perfectly flat, and they are thicker. I used them since they were on the newer frame and easier to get off. Plus, they will probably hold the monster bumper I will build .
Old Sep 3, 2004 | 09:12 PM
fishmanndotcom
i'll get back to ya on Monday abotu those springs. i will see how much it will be to ship them.
PM me with your info so i know what i am delaing with
-cutts-
Old Sep 6, 2004 | 01:04 PM
BigRed350's Avatar
BigRed350
As long as this thread is running, I thought maybe you guys could answer a similar problem I have. My truck is a '97 F-350 PSD 4x4. The front end is noticably lower than the rear by about 3 inches. All I want to do is level it out and bring up the front end. I do have a huge "monster bumper" with a catwalk which I'm sure adds to the problem. I took the truck to a local spring/suspension shop and the guy said I had 2 options. Option 1 was to replace my existing springs with brand new ones. Right now my springs are totally flat, and he said they should arch up a bit. Option 2 was to leave my existing springs there, and add a "snow plow" leaf plus he said that he would also add a piece of an old cut spring to bring up the height some more. What is a snow plow leaf? Is it a stock Ford item?
Thanks for any advise.
