Front Axle Question
Old Aug 21, 2004 | 08:00 AM
richartdana44's Avatar
richartdana44
Question Front Axle Question
I just removed the entire front end off of a 1977 F150 with power disk brakes. On a previous post, someone stated that these axles would be wider than the ones on my 1969. I measured and compared the two years, but do not see any difference. They do have different part numbers.....Can anyone tell me the difference?
I noticed that the radius arms on my 69 are forged and the 77's appear to be stamped steel. Does anyone have a feeling which would be better to use?
Old Aug 21, 2004 | 12:24 PM
FLgargoyle's Avatar
FLgargoyle
I think they're usually the same length, or close enough. According to my Chilton's, they did change the king pin angle a few times over the years, so I always change out the whole thing, rather than just spindles. I think the forged radius rods look more 'industrial'. Kewl! I don't think they are functionally different; just cheaper to make (stamped ones).
Old Aug 21, 2004 | 06:54 PM
richartdana44
Thanks. You have the same idea I came up with, using the 77 axles with the 69 radius arms. Should look awesome with everything powercoated. Can't wait to see how much better, easier, my ride will stop.
Old Aug 21, 2004 | 07:08 PM
comet's Avatar
comet
I think some people have stated that the axle perch locations are wider (due to a wider frame), but I have a '78 I'm swapping a front axle into my '71 and the perch width is the same, so not sure where this came from.
Old Aug 22, 2004 | 09:09 PM
dinosaurfan's Avatar
dinosaurfan
front axles
Rich, that could have been me. I was certain that the width was differant. I have a '71 with drums up front, and I purchased a D44 from a '76 F150. Let us know how this all works out, I am right behind you. DF, @ his Dad's
