EGR, how did it work?
Old Aug 22, 2004 | 07:01 PM
76supercab2's Avatar
76supercab2
Originally Posted by gtex
Sean, I'd be surprised. A high HP street vehicle is usually an efficient vehicle...at least it should be. I' not talking about a strictly race vehicle.
with good tuning, I bet my truck would burn cleaner than a lot of the newer vehicles on the road here in Texas that don't get tested for emissions.
I would have thought that too but.... To get more power out of a given engine you need more heat. The higher combustion temps lead to the formation of oxides of nitrogen NOx, a major component of smog. A finely tuned high performance engine can probalby get better mileage and less HC (unburned fuel) emissions than a stocker. But its NOx emissions may be increased because of the higher combustion chamber temps.
It's always a balancing act. You can reduce HC (hydrocarbon) emissions by leaning out the mixture and the engine will run better. But as you lean the mixture out your NOx emissions go up as the combustion temp goes up. 'Course if you lean it out too much you end up with burnt valves.
Old Aug 24, 2004 | 04:02 PM
BB's Avatar
BB
I was wrong, it's 1975 and earlier vehicles that are exempt from emissions testing in CA.
http://www.geocities.com/smogrfg/update/update.html
Old Aug 24, 2004 | 05:15 PM
gtex's Avatar
gtex
Electric fans, second thoughts.
Guys, I'm starting to regret the electric fan setup.
ALmost every week I have some other failure related to the fans. bad connection, blown fuse, melted fuse housing...
I'm used to building high power car audio, so it's not like I'm an eletronics novice.
But when these fans don't come on...thats' bad. And trouble shooting a connection on a hot, running motor is no fun.
At this point, who cares about the stupid 5 HP savings.
Are the flex fans a good solution?
Old Aug 24, 2004 | 05:33 PM
BB's Avatar
BB
I'd go with a clutch fan, that's what I run on the CJ.
Used to run a flex fan but got tired of all the noise it made and cutting my hands on the blades, they're sharp suckers! Plus I've heard of a few flying apart.
I believe the clutch fan will give you better mileage than the flex too, at least that's what I've heard in the '67-'72 forum.
Make sure you run a shroud with whatever you end up with.
Old Aug 24, 2004 | 05:36 PM
gtex's Avatar
gtex
oops. I meant to start a new thread...brain fart.
Old Aug 24, 2004 | 05:43 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Or, make sure the fan is very close - which I don't like
Old Aug 24, 2004 | 05:48 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Greg, if ya got rid of that damn 1000 watt amp for your music? you wouldnt have a problem running the cooling fan!!!
Ya I know Country has to be played loud!!! LMAO!!!!
Old Aug 24, 2004 | 06:06 PM
proeliator's Avatar
proeliator
I'd advise a clutch fan as well, over the flex. I'd ask if you were running heavy enough gauge wire, relay, etc. for you fan but since it sounds like your up on all that stuff...
You know, I've been running electric for years and haven't had problem one...and thats using junkyard components. Thats it! Your spending too much money on your high $$$ components, you just need to go cheap!
Sorry, your wife made me say that.
Old Aug 25, 2004 | 02:43 AM
gtex's Avatar
gtex
I'm starting to think there's somthing to that! I've had better success with a lot of cheaper components in the past. This project has a lot of money thrown at it, and it seems only to have created headaches :-( I should have stuck with the basic running 69/390 I had, and bought 1000 lap-dances instead :- )
the tunes however, sound pretty good :-)
Old Aug 25, 2004 | 03:04 AM
proeliator's Avatar
proeliator
But think how much you've learned through trial and error!
Seriously though, I've learned the most when things didn't work out and I had to figure out A) what happened, B) how to fix it, and C) how to keep it from happening again. At this point you should be reaching Yoda stage
Besides, 1000 lap dances would be cool and all, but in the morning all you'd have to show for your $ is sticky underwear. Personally, I'll take your potent Ford build up over sticky underwear anyday
Old Aug 25, 2004 | 08:24 AM
76 F150 Ranger XLT's Avatar
76 F150 Ranger XLT
Damn Greg, sounds like you either have more money into that engine than I thought or the lap dances are a lot cheaper in Texas than they are here in Maryland. A thousand lap dances here would run you about $30K. Of course that assumes you don't get some sort of bulk discount for being a repeat customer.
Heck, $30K would get you three Kieth Craft built 428 strokers at 500+ HP each. If I were going to spend that kind of money, I would get one KC motor and about 300 lap dances. The rest would be gas and tire money.
Old Aug 25, 2004 | 09:24 AM
gtex's Avatar
gtex
Well, I was including what I've got invested in the whole truck project. Remember, there's 2 trucks combined in this mess and almost nothing is untouched (suspension, brakes, all bushings, gauges, AC, on and on and on).
Lap Dances are about $20 here in Texas. Tuesdays are 2 for 1...so my money could have gone even farther :-)
When my time comes...Am I gonna look back on life and ponder this damn old truck or...........????????????
Old Aug 25, 2004 | 10:06 AM
  #28
76 F150 Ranger XLT
Only $20 and 2 for 1 on Tuesdays. Nothing like that available here in the Baltimore area as far as I know. Sounds like I need to move to Texas.
Old Aug 25, 2004 | 09:44 PM
  #29
Azguy54's Avatar
Azguy54
$7 here in Tucson......and all kinds of drink specials......wife and I go now and then........SHE asks me to go! Hmmm, maybe I been on the road too much?
Old Aug 25, 2004 | 09:48 PM
  #30
gtex's Avatar
gtex
I noticed land/homes appeared cheaper when I went through Tucson as well. If everything is cheaper in Tucson, are there any good jobs?
