Humming Noise
Old Aug 20, 2004 | 02:57 PM
DspSphinx's Avatar
DspSphinx
Humming Noise
Has anyone experienced a high pitch humming noise when driving their truck. I have 2004 F-150 Lariat Crewcab. Whenever I get up to 45 MPH there is a humming noise whenever I touch the gas pedal. If I let off the gas petal the noise disapears It only does this if I'm going between 45 MPH and 54 MPH. The noise is very annoying and it drives me crazy.
Old Aug 20, 2004 | 04:11 PM
cajun04screw's Avatar
cajun04screw
Do a search for axle whine. I have it, already replaced the ring and pinon gears in rearend did not fix problem. Haven't had time yet to bring back to dealer . Other fix is changing rear end. Other members problems were fixed with just the ring and pinion gear changed. Good luck, take it to dealer.
Old Aug 20, 2004 | 04:29 PM
HawaiianStyle's Avatar
HawaiianStyle
How many miles did you have when you took notice and where was your truck built? My Lariat is not here yet but my wife's Expy has the same whine @ 55-65mph. it's at 8000 miles now but it started when it reached the 2500 mile mark and seems to be getting louder. waiting on my truck to get here so we can drop it off at the dealership .
Old Aug 20, 2004 | 06:11 PM
xsabrz's Avatar
xsabrz
04' FX4 5.4 3.73 LS CC
21,000 MILES TODAY
8,000 miles had clunk/vibration when starting from a dead stop (making left turn).
around or about 19,000 miles whining noise started @ 50-55mph or higher speeds, release gas whining stops. accelerate whining continues.
today early morning drop off for 20,000 oil change, informed service tech.of whine.
1500 hours, FORD service tech calls to inform that possible rear end needs to be replaced. w/rental included possible 4 day fix.
Old Aug 21, 2004 | 12:39 AM
DspSphinx's Avatar
DspSphinx
Currently I have 4500 miles on it. I noticed it around 3500 miles. The truck was built in Kansas.
Old Aug 21, 2004 | 06:18 PM
fischone's Avatar
fischone
have the same problem build date on my truck 2/04 ford says that teey are working onthe problem
Aeckman
May 6, 2014 04:35 PM
Hookdup31
Aug 13, 2013 02:25 PM
Ch412
Apr 14, 2013 01:58 PM
sammatt1
Aug 1, 2012 08:41 PM
LWM97
Feb 2, 2004 01:38 PM
