don phillips
Old Aug 19, 2004 | 09:14 PM
Don Phillips's Avatar
Don Phillips
don phillips
anybody know manual transmissons?
Old Aug 19, 2004 | 09:18 PM
mymechanic'sanidiot's Avatar
mymechanic'sanidiot
No, but I know a manual garcia. Sorry couldn't resist. I don't know em but there are plenty of folks here that do. They probably hang out in the transmission forum where I imagine this will get moved. Welcome to FTE!!
Old Aug 19, 2004 | 10:09 PM
bdjupiter's Avatar
bdjupiter
Welcome to the site Don! I agree, hang out in the transmission section or hang out in the forum which best describes your truck. There are a bunch of very knowledgeable people here who are always very helpful. Welcome again and have fun.
Old Aug 19, 2004 | 10:57 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Transmissions
Don what's your location in "Kalifornia" ? What type of trans are you in question? Carl.......................o&o>................... ....................................
Old Aug 20, 2004 | 12:07 AM
Don Phillips
Roseville, near sacramento. Got a manual trans which I have rebuilt, clutch, bearings, everying. But when it get hot sometimes it won't go into 1st, 2nd and sometime reverse unless you turn off the engine. The trans shop just went through and replaced everything again and still have the same problem.
any ideas?
Old Aug 20, 2004 | 12:48 AM
"Beemer Nut"
Trans and what model?
Don is this a NP 435 box? If the inputs too tight the preload on the thrust needles will make you drag (grind) the box when it's hot. I've done a "feel" on the input shaft for years, about .004" end play, more and the taper input bearing will walk out of the race hence a loose sounding box. Whats your oil weight? I set my NP 435 box up to speed shift and sold it after 843,000 hard miles, it's still running at 555,000 miles. Carl..............o&o>.......................
Superduty450
6.7L Power Stroke Diesel
228
Dec 16, 2024 09:49 AM
pawpaw
Oil & Lubrication
Mar 2, 2016 01:58 PM
Phillip Guidry
1978 - 1996 Big Bronco
Feb 2, 2000 07:31 PM
Phillip Guidry
Nov 29, 1999 06:04 PM
