Fuel pump causing hesitation?
Old Feb 11, 2005 | 11:11 PM
LxMan1's Avatar
LxMan1
The module is the plastic assembly that has the pump and check valves inside of it. It has 3 holes in the top and a couple of screw holes on a flat spot on the side where the sending unit goes. I has a red and black wire that splice into the original wiring.
So yes, the part that you looked at is what you need. Read the directions about removing the line assembly from the unit. There is a plastic wedge included with it that makes it a lot easier.
DrZoom
Jan 19, 2017 12:48 PM
pcurtice
Sep 18, 2016 03:58 PM
Santimanzano
Aug 9, 2016 11:49 PM
TheKirbyMan
Apr 23, 2016 05:13 PM
SteelSteeds
Aug 16, 2015 07:03 AM
