haha...good tranny shop around here....haha...but that's another story. ill just have to check around and see how much the dealer here will charge to do it to see if it's worth me trying to tackle it myself.
85,000 miles without changing the oil? Wow. That maybe why your synchros are all eaten up and you have chunks in the oil. You're supposed to change the oil after the first 5000 miles and every 30,000 miles after that. You have a ZF S547, by the way.
Also, I helped my father rebuild his ZF S542 5-speed (1987 F250) and if I had done it without him, it would have been a real biatch. He's been an aircraft mechanic since before I was born and he has the specialty tools and rebuild trays so he made it look easy. Maybe an exchange unit might be a better/easier way to go. ($1700 plus shipping though, ouch.)
seems to go that way for anything on these trucks! ive prepared myself, nothing surprises me when looking for parts for these trucks. thanks for all your help 99 and Rich, ive got some researchin to do!
Here's a list of tools and part numbers that are recommended to rebuild a ZF S542. I'm not sure if the S547 will need the exact same part numbers but it'll give you an idea of what you could need:
Nylon Lifting Sling D87L-1000-A
Gear Pack Holding Fixture T87T-7025-HH
Shift Rod Support T87T-7025-JH
Holding Fixture T57L-500-B
Output Seal Replacer (4x2) T87T-7025-BH
Output Seal Replacer (4x4) T87T-7025-LH
Seal Installer Tube (4x4) T77J-7025-B
Companion Flange Holder (4x2) T78P-4851-A
Locknut Socket Tool (4x2) T87T-7025-AH
