390 overheating
Old Aug 17, 2004 | 09:23 PM
c001458's Avatar
c001458
390 overheating
I'm looking for some help. I have a 76 f100 with a 390 it was rebuilt by the previous owner. It runs at 160 while I'm on the hiway running 55-65, but when I get on the interstate and try to run 75 it starts to climb to 195 then I back off the thottle and it goes back down a little. Also climbs as soon as I get into stop and go traffic. It climbed as high as 220 within 20 min of beiing in traffic this morning before I got moving again and it dropped back to 190 but no lower. Any suggestions. It has a new 4 row radiator with shroud, 160 thermostat. Doesn't have any water in the oil or oil in the water, so I dont think the block is cracked. Possible head gasket? water pump? Any help would be appreciated.
Old Aug 19, 2004 | 03:17 PM
73Custom's Avatar
73Custom
It's designed to run 190 - 220. I've always been told it's not considered 'over heating' until its over 240.
Did it go over 220 in traffic? Try 75 on the interstate for several miles - see if it acutally goes over 220. What type of fan do you run? Is it half in and half out of the shroud?
Marty
Old Aug 23, 2004 | 06:20 PM
c001458's Avatar
c001458
Marty
The fan is half in and half out of the shroud. It's an aftermarket 7 blade. It got up to 220 in traffic but I started moving at that time so it went back down. I checked the timing and it was 12 degrees BTDC. I retarded it back to 7 degrees but not much change. It never got above 220 on the interstate.
Thanks
Charles
Old Aug 25, 2004 | 11:24 AM
73Custom's Avatar
73Custom
Since it never goes over 220, I wouldn't worry about it - if it were me.
Marty
sdetweil
186
May 25, 2010 04:18 PM
1oldtimer
Apr 28, 2010 12:17 PM
spyder90
1997 - 2003 F150
Dec 2, 2009 09:38 PM
jasonmerlo
21
Feb 24, 2007 06:39 PM
serczh1
13
Aug 2, 2003 02:17 PM
