which 5th wheel hitch
Old 08-17-2004, 08:48 PM
04superduty's Avatar
04superduty
04superduty is offline
i have been looking for a sliding fifth wheel hitch (16k) and cant decide what to get. Reese and hidden hitch seem very good to me, the hidden hitch having 12" of travel, verses 9" for the reese. I just need some personal opionions and wonder what everyone thinks and other companies to look at.
Old 08-17-2004, 09:11 PM
BratsV10's Avatar
BratsV10
BratsV10 is offline
I have the Reese kwik-slide 16k, installed myself. I have no complaints, has worked as promised so far. With the hitch slid back I can manuever as well as a long bed can. Can't speak for any others.
Old 08-17-2004, 09:33 PM
johnsdiesel's Avatar
johnsdiesel
johnsdiesel is offline
Check out Husky. My parents have one and have been very happy with it. The latch seems like a better design than most.
Old 08-18-2004, 06:28 AM
captjohn's Avatar
captjohn
captjohn is offline
Check out RBW hitches. I have had it for about 9 years and have had no problems with it however it is not a slider but they do make them.
Old 08-18-2004, 08:37 AM
rver's Avatar
rver
rver is offline
Pullrite is Great
I have been using the Pullrite Superglide slider hitch for 3 years now and would highly recommend it.... It automatically move your pin back as you turn and that just takes all of the concern away when pulling a large fifth wheel (I have a 37' unit)....It's pricey but when you consider how much you are paying for your fifth wheel the cost of the hitch is small in comparison to the worry and possible repair cost to fix a dented cab/fiver front end....
Old 08-18-2004, 08:47 PM
04superduty
some very good info so far and thanks for all the replies and advice. anyone else with info??
Old 08-19-2004, 05:08 PM
allank's Avatar
allank
allank is offline
Smile
I have an 03 F150 SB and bought a used TT which came with a Lil Rocker 5th wheel hitch. I stressed over placement and what to do about needing a slider, etc. for 2 weeks, when I finally bit the bullet, placed it directly over the axle, realized I could extend the king pin box 2 inches and just finished a 600 miler with ZERO problems. Drives like a dream. HOWEVER, if you are considering the Lil Rocker, and it is a nice solution, they have recently come out with a new "pin compatible" slider that fits the existing rails. I didn't need it but someone else out there might want it for comfort sake. Its called a PS-1001 and hardly anyone knows about it.
Old 08-21-2004, 09:15 AM
huntercgr's Avatar
huntercgr
huntercgr is offline
I just had a Hijacker slider installed and so far like it. Very heavy duty. I hear a lot of good things about the Husky too. Just make sure sure it has a double pivot head. Most of the 16K models do.
Old 08-26-2004, 10:22 PM
davejostef's Avatar
davejostef
davejostef is offline
I have been using the RBW Lil Rocker for 7 years and have had no problems towing two 5th wheels. It's not a slider though.
