I Have An Early 2003 F350 Cc Psd 4x4 With A 11/02 Build Date. Long List Of Problems. Bad Fuel Sending Unit In Fuel Tank.check Engine Light Came On Would Come On Towing Trailer.icp Code Set Dealer Changed Icp Sensor 3 Times. Had A Rear Main Seal Replaced. Had A Surging Problem Replaced Turbo.tires Dipping On Front Had Tires Rotated And Tow In Changed.i Finally Found A Tech That Knew What The Starting Problem Was He Changed The Proccesor And The Truck Runs Better Than It Ever Has.with Only 8400 Miles I Hope The Problems Are Finally Over.
I moved you over, the members here are some of the best there is on the 6.0.
They will probably want a bit more info...so be ready to do some typing...
Could you provide your VIN? We can be of alot more use to you with it
Welcome to FTE ...wish you would have found us sooner as some of your issues mat have been fixed sooner and with less anxiety.
It sounds like you feel your issues are resolved. If not post, your questions and these guys will jump on it like ....well... they will jump right on it.
What part of Oklahoma are you in? BTW: It is OK to be from Oklahoma. As Ayoung child I lived in Sapulpa for a while. But, don't tell anybody.
Enjoy your new found freedom with your newly working truck. (Is newly a word?)
Is good to find a tech that has worked on diesels for 15 years. Some of the techs have been to school to be trained on diesels but there is no subitute for experience and I have found a dealership that works on fleet and heavy trucks only.Thanks for input from you guys.
