SOHC or DOHC
Old Aug 17, 2004 | 02:22 PM
ReDeXpi7's Avatar
ReDeXpi7
Question SOHC or DOHC
Hey guys I have a 00 expedition 5.4l and was wondering what the heck SOHC is and DOHC and what I have in my car. Might sound like a dumb question but for me I am confused thanx for any help
Old Aug 17, 2004 | 02:45 PM
85e150's Avatar
85e150
S ingle vs. D ouble Over Head Cam.
Mod motors in come in both flavors, depending on application. I think the Expedition gets the SOHC motor and the Navigator gets the DOHC.
Your door sticker and/or VIN will have an engine code which your owner's manual or someone here can translate for you.
There are obvious visual differences in the motors as the DOHC set up is much wider at each head, but I can't tell you exactly what they are.
Old Aug 17, 2004 | 04:22 PM
PaulC's Avatar
PaulC
On a SOHC engine, one cam operates all the valves that populate a cylinder head.
On a DOHC engine, two cams operate all the valves that populate a cylinder head.
Old Aug 17, 2004 | 04:36 PM
HomerWinzlow's Avatar
HomerWinzlow
DOHC = More Parts, More Power, More Pain when it breaks.
Old Aug 18, 2004 | 09:37 AM
buzzard's Avatar
buzzard
Generally speaking a cylinder has two valves, one for intake and one for exhaust. The double overhead cam engines have more valves, three or four, to increase performance, efficiency, etc.
Old Aug 18, 2004 | 04:08 PM
ReDeXpi7's Avatar
ReDeXpi7
Hey thanx for all the help currently I have an eddie bauer with 6 inch lift and 35s I have two chamber flows and KN air filter what do you think my next upgrade should be to get more power....
Old Aug 19, 2004 | 11:06 AM
buzzard's Avatar
buzzard
Start with a superchip then graduate to a blower if you still want more power.
Other areas you can get a little more power are: 1. electric fans, 2. underdrive pulleys, 3. larger tb but you need to port and polish the neck it is attached to in order to realize any gains.
With 35's, gears would be where I'd start for performance gains.
Old Aug 19, 2004 | 03:49 PM
ReDeXpi7's Avatar
ReDeXpi7
Thanx ya I was thinking of a chip how much would I gain with either throttle body or cold air intake?
Old Aug 20, 2004 | 12:04 PM
Matt03Expy's Avatar
Matt03Expy
Lose the lift and go with 31 inchers.
