1978 - 1996 Big Bronco
Throttle Cable
Old Aug 17, 2004 | 11:05 AM
ZAD's Avatar
ZAD
Throttle Cable
I HAVE A 1995,302, FULL SIZE Bronco.There are a few problems that I have.
First:I have to replace the throttle cable and I would like to attempt this with my son and myself and I need some help as I never did this before.My mechanic told me that I should be able to do it with no problem.
Second; Recently when it is started the RPM'S go way up.This doesn't happen all the time but when it does I have to shut it off and try again to bring it to normal idle.A friend mentioned that there maybe a sensor that controls the RPM.Again can I do this myself or should I have a Mechanic.
Thank you.
Zad
First time posting.
Old Aug 17, 2004 | 11:13 AM
BillyBob69's Avatar
BillyBob69
The cable is easy to replace. Takes about 10 minutes. The pedal end requires no tools...jsust push the plastic retainer back and lift the cable off of the pedal. push the cable through the firewall, pry the end off of the throttle body and done.
There is a sensor on the throttle body I believe it is called the TPI. (Throttle position sensor) I have had to remove mine and cleaned it a couple of times but each time it helped. This could be one issue. The cable could also have other probs and could fix the high RPMs.
Change out the cable first and see where you stand after that.
WELCOME TO BRONCO LAND!
This is a great forum for help and ideas. I have done so much more on my truck from help from this forum. Lots of good knowledge here.
Old Aug 17, 2004 | 11:54 AM
ZAD's Avatar
ZAD
Thank you for your help.I will let you know how it works out.
Zad
Old Aug 17, 2004 | 11:02 PM
ucmeflyby's Avatar
ucmeflyby
Zad,
I just replaced my cable last night, took about ten minutes and $30 to buy the replacement cable. You can do it no problem, good luck.
Old Aug 18, 2004 | 11:23 AM
ZAD's Avatar
ZAD
ucmeflyby
Thanks alot for your help.
I just bought the cable.I won't be able to replace it until Saturday and I will let you know.It is my son's car so I am going to put him to work.
Zad
Old Aug 23, 2004 | 08:26 AM
ZAD's Avatar
ZAD
Thumbs up
Thanks to everyone,
I installed the throttle cable for my son's 95 Bronco.Worked out well.
Cost about thirty dollars.Your advice priceless!!
Next question.Speedometer pins when driving.It goes to the max and just stays there. Any ideas.
Thanks Again
Zad & Son
Old Aug 23, 2004 | 09:29 AM
kaised's Avatar
kaised
Maybe the VSS (vehicle speed sensor) is bad?
Old Aug 23, 2004 | 09:37 AM
ZAD's Avatar
ZAD
Thanks for quick reply.
Is this something My son and myself can check and or replace?
We are trying to work on this together.
Zad
Old Aug 23, 2004 | 09:54 AM
BillyBob69's Avatar
BillyBob69
If I remember correctly, the VSS is located towards the top - front of the rear differential. Not a prob to change.
Anyone else confirm or disagree with that?
Although mine is and 85, I have gone through alot of threads in here that said that was the location.
Here is a link that may help in the location and replacement.
http://www.autozone.com/servlet/UiBr...3d800a38dd.jsp
I couldn't find the VSS but it looks like your speedo is mechanical. Could be an issue with the gearing on the cable.
Old Aug 23, 2004 | 03:08 PM
ZAD's Avatar
ZAD
Thanks for your help.
I think it started when we had the tranny serviced if that is any help.
ZAD
Old Aug 24, 2004 | 09:03 AM
BillyBob69's Avatar
BillyBob69
Could be the cable was never re-connected correctly. Worth a look.
