1978 - 1996 Big Bronco
'96 Full Size Bronco HELP needed
Old Aug 17, 2004 | 09:31 AM
WBRWOLFMAN's Avatar
WBRWOLFMAN
Hello Everyone,
I am new to this site, but need help in a project '96 Eddie Bauer Full Size Bronco (clean VIRGIN Body from FLA.). I have taken the 351 out and wish to put in a '79 460 w/C6 that I have . I was told it will bolt up with c6 , I have motor mounts, but do not know the correct way to hoop up wiring ?? the 351 was EFI, I unpluged everything, NOT CUT.... and the 460 is carborated. The 460 has stock intake and wish to put BETTER intake on ( I have a Holley 650 - single feed - carb. to put on ) Will an edelbrock intake work ?? or what suggestions do you have for a GOOD intake to put on for POWER / performance value. I am building the truck for personal use, NOT drag / Mudding. I would drive it on street as well as off road ( if situation came up ) . The 460 is stock - rebuilt to original with many new parts, pistons / valves were NOT changed - in Great shape. I want to upgrade the carb/intake first, get it installed and hooked up, and go from there.....Any Help - I am stuck on which intake to get now ?? - would be GREAT !! Hope I find a Bronco enthusiest out there to help, I have Loved the Bronco sense I was a Teen, Now I have a chance to build the LAST of the Bronco's !!
Thanks,
Bill W. - Mason, Michigan
Old Aug 17, 2004 | 10:57 AM
beastybronco's Avatar
beastybronco
a 460 is a great motor but if ur not going to really use the extra power then y take the 351 out? i am not trying to down ur idea i only wish i could get my hands on a 460 and had the know how to rebuild and install it
so whats happening to ur maf computer and sensor now?
Old Aug 17, 2004 | 11:30 AM
NascarNut's Avatar
NascarNut
Check out the 385 series engine forum and do a search, I'm sure you will find what your looking for as far as performance.
Pleas let us know how it goes and take some pics!
Old Aug 17, 2004 | 11:54 AM
Kemicalburns's Avatar
Kemicalburns
I will say that if you have smog inspection were you live then you will fail because of that motor regardless of how it runs. being a 96 with MAF you can get alot of power out of it and keep good road manners to.
if you do go this route, L&L products sells mounts and headers that would be a good power increase.
good luck
Old Aug 17, 2004 | 12:36 PM
WBRWOLFMAN's Avatar
WBRWOLFMAN
Talking
Hi, Well the 351 has 130,000 miles and I have a fresh 460 and BIG ideas for Lift on this bronco, I had a '79 that I put a 460 in (many years ago) and LOVED the POWER !!....
Old Aug 17, 2004 | 12:39 PM
WBRWOLFMAN's Avatar
WBRWOLFMAN
Hi, I will check it out, I am taking Before and After Pic's , This Truck is Spic / Span clean so should be Super when I am done. I will post
Old Aug 17, 2004 | 12:43 PM
WBRWOLFMAN's Avatar
WBRWOLFMAN
Hello, I live in Michigan, NO smog inspection, I have a '91 now ( 302 stock ) with headers 6" lift 35 tires that I was going to put the 460 in, (Mich. Truck and RUSTED !!) then I found the '96 that was super clean. L&L, good I will check with them, Thanks,.......Bill
good luck
Old Aug 17, 2004 | 01:12 PM
beastybronco
so parting the 351? what im trying to get at is im wondering if ur selling MAF computer and sensor? i am thinking of converting a mustang but one with all the pins in the right place would be easier
Old Aug 17, 2004 | 07:38 PM
NascarNut's Avatar
NascarNut
You might want to check this link out...I don't know if it will help or not.
http://ylobronc.users.superford.org/460/
Redneckfordf2502002
85
Oct 5, 2017 05:47 PM
Redneckfordf2502002
Apr 6, 2016 11:10 AM
ekinslow67
Jun 20, 2013 01:40 PM
frdfn
Jan 23, 2004 09:21 PM
jilek
Nov 15, 2001 09:14 PM
