Intake porting
Old Aug 17, 2004 | 08:44 AM
MXZX1100cc's Avatar
MXZX1100cc
Intake porting
Will porting the upper and lower intakes on a 93 F-150 with speed density do anything. Just wondering because they will be comeing off to change a leaky valve cover gasket. Thanks
Old Aug 19, 2004 | 12:14 AM
drewcoolness99's Avatar
drewcoolness99
if not then it would probably help just to clean all the crap out of them
Old Aug 19, 2004 | 08:26 AM
holland501's Avatar
holland501
While porting won't hurt, you won't notice anything unless you spend a lot of time running wide open. Good luck.
Old Aug 19, 2004 | 11:30 AM
95 F150's Avatar
95 F150
You wont have to pull the lower intake to change the valve cover gaskets, just the upper to access the passenger side valve cover. As far as the porting like mentioned above you won't notice much of a difference.
