Will it fit?
Old Aug 17, 2004 | 01:09 AM
200k+94 F150's Avatar
200k+94 F150
Will it fit?
Will the EFI assy off of a "94" 5.0 (F150) fit on a GT40 5.8 ? I was thinking the deck hight would be different, making the manifold too small. New, larger injectors would be needed as well as a larger throtle body I would think.
Let hear it folks....
Thanks....
Old Aug 17, 2004 | 07:15 AM
EPNCSU2006's Avatar
EPNCSU2006
It won't work. You need a 351 manifold because the 351 is bigger than the 302. Depending on the horsepower of the motor you are building, 19 pound injectors might be fine (I believe they are good for right around 300 horsepower). Far as I know, the throttle bodies on 351 and 302 F150's are the same size.
Old Aug 19, 2004 | 12:19 AM
drewcoolness99's Avatar
drewcoolness99
you would only need the lower manifold off a 351, and yes according to fordfuelinjection.com you can run up to 310 hp
