94 Explorer EEC-IV Code 186
Old Jan 28, 2001 | 12:18 PM
wilbanks's Avatar
wilbanks
I am getting a fault code 186. The check engine light comes on for a few seconds when I accelerate then resets. My Haynes manual says the probable cause is "injector pulse width higher than expected" but does not tell me what sensors control this or how to check them. Can anyone help me on this?
Old Jan 29, 2001 | 02:13 PM
Mikeman's Avatar
Mikeman
This could be related to the MAF sensor. Try cleaning it and resetting the computer and see if it helps.
Old Jan 30, 2001 | 05:27 AM
wilbanks's Avatar
wilbanks
Many thanks Mikeman. I cleaned the MAF sensor with carb cleaner, reset the computer and no more 186 code. The process is easy, just remove the two screws holding the MAF sensor in the air intake. Spray clean with carb cleaner and replace, clear the fault codes and test drive. The only hard part is finding the tamper proof torx screwdriver to remove the screws. I drilled out the end of a regular torx driver.
Old Jan 30, 2001 | 10:49 AM
patchy's Avatar
patchy
bigds01
6.2L V8
Mar 20, 2016 09:27 PM
Ford11
Mar 10, 2016 09:26 PM
bvillarreal186
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 24, 2015 08:56 PM
llesg
43
Jan 31, 2013 01:45 PM
blue93explorer
Aug 16, 2004 06:05 PM
