1978 - 1996 Big Bronco
Rear diff. speed sensor???
Old Aug 17, 2004 | 12:23 AM
Corbin18's Avatar
Corbin18
I have a 89 bronco with a 5.8L. I am swapping out the rear end and was just wondering what the rear speed sensor does and what it will hurt not being there???? I do not have abs so I don't know what this is for???
Old Aug 17, 2004 | 06:54 AM
fcarruth's Avatar
fcarruth
If you don't have ABS, it was altered bysomeone because your 89 does have ABS as does mine. That sensor pretty much works in conjunction with the ABS system. Others will have more detail than me but I just wanted to add that quick info.
Good luck,
Old Aug 17, 2004 | 12:01 PM
Kemicalburns's Avatar
Kemicalburns
what are you putting in its place. removing it will just disable the RABS which doesnt work that well to begin with. I swapped to a 9" rear and it drives fine. it will lock up when i really really stop fast but thats ok . your abs light will stay on so you can either tape over it or remove the bulb behind the dash.
late
Old Aug 17, 2004 | 03:36 PM
Corbin18's Avatar
Corbin18
Do you have to remove the RABS valve?? Thanks for your help!!!
Old Aug 17, 2004 | 03:44 PM
Kemicalburns
i didnt and seems to stop fine for me.
Old Aug 17, 2004 | 03:57 PM
Corbin18's Avatar
Corbin18
Awesome Thanks for your help!!!!!!
Ford_F350SD
Jun 14, 2013 03:20 PM
1995droptopz
Jul 15, 2011 09:48 AM
maverick1701
Oct 6, 2008 09:33 PM
HaroldCallahan
1983 - 2012 Ranger & B-Series
Nov 15, 2005 08:47 AM
bronco cam
Dec 28, 2003 11:53 AM
