Computer Chips & Tuners
casper electronics throttle enhancers
Old Aug 16, 2004 | 11:59 PM
muscletruck7379's Avatar
muscletruck7379
flipping through the summit i found a part that goes between the tps and connector and is supposed to add fuel and advance timing when the throttle is open %70 or more to cure hesitation. i became a interested cause' the ranger that im looking at has hesitation when you open it up. has anyone used one of these? and are they worth the 90 bucks?
Old Aug 17, 2004 | 02:25 PM
openclasspro's Avatar
openclasspro
just adjust your tps voltage
Old Aug 17, 2004 | 10:48 PM
FTE Ken's Avatar
FTE Ken
Has this hesitation always been there or is it something that has developed over time? What Summit is selling is basically a gimmick resister. It just bumps up the throttle reading, the same effect can be made by pushing the pedal further down.
Old Aug 18, 2004 | 03:00 PM
openclasspro
do the same as on dodge ram throttle bodies- drill out brass inserts so you have adjustment with key on not running- adjust to roughly 1.0 volts- - i look up spec for best response- this is not the same as pushing down a little more on the gas pedal!
