Glow Plug Control Module
Old Aug 16, 2004 | 12:55 PM
safetyguy2001's Avatar
safetyguy2001
Exclamation Glow Plug Control Module
The check engine light is on in my 2000 Excursion PSD. I had the code read by the local parts store. It came up as a problem with the Glow PLug Control Module. Its about at $120 part. Is this something I can replace myself? Where is it located?
Thanks,
Shawn
Old Aug 17, 2004 | 05:45 AM
Quadzilla's Avatar
Quadzilla
The only piece you have that controls your glow plugs is the glow plug relay. Though this part is quite expensive at Ford, NAPA carries a glow plug relay for our trucks for about $20-25. The part number is GPR-109. If you remove the plastic engine cover on top of the engine, you'll see the gpr sitting off to your left, on the passenger's side. It has two large terminals, and two small ones. You can't screw up installing the new one. The small wires go to small terminals, and the large wires go to large terminals. Don't worry about which small wire goes to which small terminal, it doesn't matter.
I hope this helps.
Old Aug 18, 2004 | 01:56 PM
safetyguy2001
I hope this helps.
Thanks for the reponse. I checked on fordpartscheap.com and found two parts:
glow plug module assembly for $168
glow plug relay for $77
Are these parts the same?
Shawn
Old Aug 18, 2004 | 05:31 PM
Quadzilla's Avatar
Quadzilla
Probably not. Your truck might have a module and a relay. Mine only has the relay. The $77 relay would be replaced with the one from NAPA. They might also carry a replacement for the module, too, but I haven't checked.
croweyes
Nov 10, 2014 09:06 PM
Padlock
Oct 26, 2014 08:09 AM
david moore
Sep 10, 2011 12:33 PM
trailshredder
Dec 3, 2008 12:02 PM
powerglyde1234
Nov 7, 2005 10:31 PM
