Sponsored by: Kumho
Windstar Steering Noise
Old Aug 16, 2004 | 11:08 AM
gpeade's Avatar
gpeade
Question Windstar Steering Noise
I Have A 2000 Windstar And When You Turn The Wheel It Sounds Like The Struts Are Grinding Thru The Fenders. The Best I Can Tell Is That The Noise Is Coming Directly From The Struts. Is This Correct And Can It Be Corrected Without Replacing The Struts
Old Aug 17, 2004 | 04:15 PM
youngblue's Avatar
youngblue
Yes it can but the struts will need removed. If this noise is a grunting\popping noise at speeds below 20 mph, parking manuvers, etc, there is a bulletin out on this. You are supposed to install a spacer (2F2Z-18A027-BA) between strut assembly upper mounting bracket and strut tower. Then Align vehicle. This a bulletin for professional tech use only. You may want to have it done.
Old Aug 18, 2004 | 07:29 AM
gpeade's Avatar
gpeade
Do You Have The # And Specifics On The Tsb Because I Have A Good Friend In The Alignment Business(just In Case He Us Unaware Of The Fix). I Sure Don't Want To Take It To The Dealer. Don't Feel Like Refinancing To Pay For Repairs, Know What I Mean
Old Aug 18, 2004 | 12:17 PM
youngblue's Avatar
youngblue
I can get it if you need it but it is a current bulletin on ALLDATA. I would have to look again.
Old Aug 18, 2004 | 03:11 PM
youngblue's Avatar
youngblue
The number is listed as 02-13-2 in ALLDATA. Don't know if that is the Ford #. You just get the parts by the # provided, remove struts, install on top of the strut mount then reinstall struts and align. See ya
MjrMinor
Jan 7, 2020 05:33 PM
AGrayson84
Oct 25, 2016 12:14 PM
mrgriz
Nov 8, 2015 10:21 PM
teammaico
Nov 6, 2015 05:30 PM
