Antenna replacement on Explorer
Old Feb 20, 2001 | 09:09 PM
sixthofgod's Avatar
sixthofgod
I currently have one of those glass-mount cellular look-alike CB antennas on my 94 Explorer. I want to change to a higher quality antenna with better performance and tunability.
I've seen CB antennas that are dual-band or even tri-band, and would like to have a single antenna to use for AM/FM and CB. Ideally, I would like to put the new antenna on the corner of the hood, where the factory AM/FM antenna currently is.
Do any of y'all know if there is some type of adapter or mount that can be put into the place where the factory antenna is, or if such an adapter or mount even exists?
Old Feb 20, 2001 | 11:12 PM
jbhf250's Avatar
jbhf250
I welcome you as a new member
It may help you to repost your question in the proper area to get the answer you need ....Some members only `post` responces in the area they are acustomed to reading..
>>Topics do not have to be about automotive products. Anything goes so long as its clean. DO NOT USE THIS FORUM FOR QUESTIONS ABOUT YOUR TRUCK, USE THE APPROPRIATE SECTION<<
__JOHN__Õ¿ö
FTE Club #7
Member-
http://www.cruisin-north.com/
Santa Rosa, Calif.
72 F-250
ICQ#6030753
http://www.ford-trucks.net/users/jbhf250/
https://www.ford-trucks.com/pictorial/big/1972_f250_2.html
Old Feb 21, 2001 | 08:09 AM
larrycreed's Avatar
larrycreed
