Which Carb to Use ????
Old Aug 16, 2004 | 09:23 AM
Edge Motorsport's Avatar
Edge Motorsport
Question Which Carb to Use ????
Hi guys,
I have a '75 360 4x4 4sp...
Im planning on a set of long tube headers and probably the edlebrock aluminum heads... my question is which carb should i use. Curently on the truck is the stock 2bbl ford item with stock manifold. I was thinking of a holley 600cfm vac. secondary 4bbl on a performer manifold (or maybe a performer RPM)
Is this likely to be enough carb or shuld i look at a holley 650 double pupmer 4bbl ????????????
Any help or advice would be appreciated
cheers
EDGE
Old Aug 16, 2004 | 10:45 AM
Mike G's Avatar
Mike G
The 600 should be plenty. Go with the Performer RPM, especialy if you plan on stepping up to the aluminum heads.
Just my $.02, --Mike
Old Aug 16, 2004 | 12:30 PM
rusty70f100's Avatar
rusty70f100
The Performer RPM heads are well matched to the Performer RPM intake, and work well together. If you use the stock heads they WILL work well with the RPM intake if you port match the heads to match the ports of the intake. See my thread "Porting Revisited" for more instructions on this. If you use the RPM intake and leave the heads alone, it'll flow like poop and you wont be happy.
The holley 600cfm vacuum secondary is an exceptional carb for any 360 and most 390's. Use it.
racenitro
Aug 21, 2016 08:53 AM
Rusty_S
34
Jun 22, 2016 02:29 PM
Rusty_S
Jun 22, 2016 07:52 AM
otis348
Oct 8, 2004 05:12 PM
serving_time
89
May 25, 2004 07:25 PM
