fuel pump power bypass
Old Aug 15, 2004 | 10:27 PM
chrono4's Avatar
chrono4
I was wondering if it would hurt anything to put in a switch to controll when the fuel pumps come on. on my 88 f150 none of the 3 pumps will kick in so i figured i could just put in a toggle switch or something of the like. any help will be appreciated.
thanks, chrono
Old Aug 15, 2004 | 11:06 PM
drewcoolness99's Avatar
drewcoolness99
thanks, chrono
you could but it would be a good idea to hook it up to the ignition switch if you do. just i case you forget and leave it on.
Old Aug 16, 2004 | 10:49 AM
chrono4's Avatar
chrono4
ok thanks. i was thinking of where i could wire it into. so finnaly my ttruck will be up and running. thanks chrono
Old Aug 16, 2004 | 12:41 PM
drewcoolness99
just make sure you don't wire it up with a guage of wire too small for the current.
Old Aug 16, 2004 | 09:10 PM
tmrider's Avatar
tmrider
Question fuel pumps
If there are 3 pumps on a 88 150,does a 87 F250 with two tanks also have two pumps.
Old Aug 16, 2004 | 10:22 PM
drewcoolness99
if it has 2 tanks it will have 3 pumps no matter what. unless its carbuereted. Theres 1 in each tank then the one on the frame rail.
Old Aug 18, 2004 | 01:32 AM
chrono4's Avatar
chrono4
on the front fuel tank which cables are the pump power supply. i dont want to hurt the sending unit.none of the cables are what i would think they would be. now that im inside i dont remeber the colors. any help will be greatly appreciated.
thanks chrono
Old Aug 18, 2004 | 12:05 PM
SoFla David's Avatar
SoFla David
Before you go re-wiring,
Have you checked the fuel pump fuse, relay, and the cutoff switch under the dash?
also, even though there are three pumps, you do know that only two run at a time right? (Depending on which tank you want to use)
Old Aug 18, 2004 | 09:38 PM
chrono4's Avatar
chrono4
yea i checked it all. and i already did it and it works great. i just tapped into the supply for the pumps originally and ran it to a switch on the dash so i can have it on normaly and when im just sitting there with the key doing whatever i can turn them.
Old Feb 18, 2025 | 04:46 PM
Hunterdyer25's Avatar
Hunterdyer25
5th Gear
same issue with my pumps I've been wanting to do this forever PLEASE explain your wiring. So which wires from front tank pump need hooked too power and grounded through the switch, and then did you wire up the high pressure pump too a switch as well?
Old Feb 19, 2025 | 08:12 AM
Scndsin's Avatar
Scndsin
Time to start a new thread.
This one 21 years old.
Chrono hasn't been on site in 13 years.
Old Feb 19, 2025 | 10:27 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I don’t understand why anyone would do that. Fix the problem!
Hunterdyer..Scndsin is correct. Please start a new thread explaining what is wrong.
