Problem Clutch
Old Aug 15, 2004 | 09:47 PM
tmrider's Avatar
tmrider
Question Problem Clutch
Have a 87 F250LD with a low clutch pedal.Thought to have a worn clutch because when just barely letting my foot off the truck would move.after further inspection I found that when I pushed on the clutch pedal the master cylinder for the clutch would push away from the firewall.Is that piece of sheet metal on the engine side that the clutch and brake master cylinders are connected to spot welded,if so should I have it welded or just drill a coule holes and bolt it. Tony
Old Aug 16, 2004 | 11:15 AM
aguylookingforadvice's Avatar
I would drill and bolt it..if you need to replace it later on down the line it would be a pain in the @!# - Good luck!
Old Aug 16, 2004 | 08:54 PM
tmrider's Avatar
tmrider
Thumbs up problem clutch
Thanks for getting back.I did bolt it in place and the clutch pedal is now where it should be.Now I have to figure out a different setup where the chutch pedal linkedge connects to the rod of the cylinder.Tony
Old Aug 23, 2004 | 11:38 PM
Katmandu's Avatar
Katmandu
Where do you place this Bolt ??
Got pics ???
Old Aug 24, 2004 | 08:40 PM
tmrider's Avatar
tmrider
Smile
Got pics ???
Sorry no pics.I drilled a 3/8 hole about a 1 1/2 inches to the right of the top mount of the clutch master cylinder.I used a 12inch long drill bit to sqeeze between the clutch master and the brake vacume booster to do it.It was a pain in the butt,but it worked.My truck goes on the road next month.Tony
rideracelivemx7
Apr 10, 2011 08:12 PM
fordopie
1983 - 2012 Ranger & B-Series
Oct 11, 2009 09:20 AM
mfoxcontract
Mar 13, 2007 10:07 PM
xc4life_nemo
Nov 9, 2006 06:38 AM
Tony G
Jul 15, 2004 01:35 AM
