1978 - 1996 Big Bronco
Help 95 bronco
Old Aug 14, 2004 | 05:24 PM
stnl4's Avatar
stnl4
Help 95 bronco
Can't get my truck in gear I took off the shifter cable and can shift the gears easy from under the truck but when I put the cable back on the part where the shifter handle goes wont move unless i wiggle my key
Old Aug 14, 2004 | 10:20 PM
Trublufords's Avatar
Trublufords
Check brake light fuse- or just get someone behind you to see if they work!!Temp. to get out of park- turn key just before on(if radio comes on you are too far) put shifter in neutral and start truck.
Old Aug 15, 2004 | 04:59 PM
stnl4's Avatar
stnl4
thanks
Thanks I had a blown fuse but it was for mt cig. lighter still no brake lites couldn't even find the fuse fot them
Old Aug 15, 2004 | 08:03 PM
stnl4's Avatar
stnl4
Thumbs up I got it
I got it thanks
